Originally Posted by Frankie1588
Ok, I think something weird happened when switching back and forth between the DVDO Edge and straight to the TV. It made the situation worse when I switched directly to the TV.
I shut the PS3 off and plugged it directly into a different HDMI input. The effect is still there, but its not as bad as it is in that 2nd picture.
I apologize! I should have double checked this first.
I'm going to get some new pics up here in a few minutes.
It has 3D pass through. You can use it with 3D, but the DVDO Edge will not do any video processing to it.
Here are some new pics. I made absolutely sure the completely shut off the PS3 before switching from directly to TV and the DVDO EDGE
Pure TV
DVDO Edge
Still quite a big difference. I will try to get pics of more games later today.
When you put the DVDO Edge in game mode (like I have in those pictures) it disables the sharpening tools in the DVDO menu, but it only adds 6ms input lag to the TV's input lag (from what I have heard from numerous sources)! I couldn't really tell any difference.
http://www.highdefforum.com/1085823-post7.html
Pure TV
DVDO Edge
Your also zooming in on the pics with the DVDO Edge which you said made the problem go away somewhat when objects are close up. If you compare the pics the DVDO Edge pics are more zoomed in. You should make them exactly the same.
