Originally Posted by thomfam
I have a media player, subscription PayTV and DVD player connected via HDMI to my 50" ST50. My older model Yamaha Tuner/Amp only has "Component" connections. Most times I run the audio via the HDMI connected to the TV and then connect the audio to amp via a toslink/optical cable running from the TV optical out to an optical in on the Yamaha......
Our old Pioneer HTR also knows nothing of HDMI ports: we run HDMI from both the blu-ray and HDDVD players to the tv, but also run toslink cables from each player to the receiver.
For our Uverse (cable tv) box, we run Component Video cables + stereo audio to the tv, again with a toslink to the receiver.
Our LR system is set up similarly - albeit without the HDDVD player. The receiver there is newer, but a less expensive model, and still lacks HDMI ports (although, thankfully, both of these receivers DO handle DTS - which is apparently the default, or Only, audio mode for most blu-rays - ??).
This cabling setup has worked fine for nearly 5 years. (The CRTs we had in place prior to that time - & our first plasma purchase - had Component Video as their best input. Our oldest "HTR" only decodes Dolby Pro Logic: for "5.1 Surround" you needed a source that would feed analog channels to the receiver.)
