Originally Posted by
KurtCocain
All right can someone clear up what is the best way to have flawless streaming of HD to the TV? I am sure the port on the ST50 is not a gigbit, but if I connect the TV through ethernet and then have a PC connected through ethernet cable is that the best? what if my laptop is on a wireless but the TV wired -- would that work? Also, I have to buy a new router so I cannot figure out what best to put money into. A router which supports N, but also has a USB so that I can attach a pin/hard drive, but then the router would need to be DLNA certified in order for the TV to see and play from the drive attached to the router? It is all a it mess for me... A[[reciate if anyone can shed some light on this.
I can only relate my own experience... I got a Netgear 3700 wireless router, which is one of their higher end consumer grade routers, about $180 street. It has 4 ethernet ports. I have WOW cable for both Internet access and tv, seperate cables come up through the basement, one off a splitter goes to the big tv in the family room, another cable plugs into the router in the den which is split off again to also feed another tv in same room.
Now I've heard lots of BS that ethernet is fast (well sort of) and it beats wireless hands down as far as throughput. My experience for what I'm doing, big yawn. My main PC in the den is connected to the router via ethernet. I also purchased a Qnap NAS which I'm in the process of moving all my multimedia files too...several TB's worth., so they are available on my home network regardless if the PC is on or not, since I'm keeping the router always on. The original "fun" part was coping files from my PC to the NAS. Because the PC is connected to the router with ethernet and the NAS to the router with ethernet I thought copying the files would be bing, bang, and done. No. In spite of all the claims Qnap made, actual real world data transfer using this method was painfully slow. Something on average between 30-40 MG a second. Which isn't really slow, but not as fast as I thought it would be so took many hours. That's a one time thing, so not a big deal.
Now how it works real world. I have loads of images in JPEG format, the same for music in MP3 format and also thousands of video files typically in MPEG-2 or MPG-4 format. What's more important isn't the format, but the bitrate which both determines how big a file they are and the viewing quality. Well using either my Panasonic ST50 tv through it's DLNA feature (using a media server) or another tv on the network or a cellphone or tablet these videos stream flawlessly so far no stutter or any playback issue all going wireless. I had originally planned on running a ethernet cable from my router in the den to the big screen tv in the family room thinking it would be needed, but now testing it real world don't really see the point. Oh, the bitrate of the vids is typicall 8-9 megabits a second which is good quality. So while the tv has ethernet and USB inputs it works perfectly well for my needs using wireless as do all the other devices I've tried.
