Originally Posted by rahzel
Just Scan is usually a label for 1:1 pixel mapping mode on most sets. On the Panasonic, HD Size 2 is 1:1 pixel mode.
For 24p, there's essentially 3 options on the ST50:
1. Output 24p and set the ST50 to 48Hz
2. Output 24p and set the ST50 to 60Hz
3. Output 60Hz
Option #1 has no converting, just frame doubling; however it has significant flicker due to the low refresh rate. Option #2 forces the ST50 to convert 24p to 60Hz and is smooth like 48Hz, but it has some minor artifacts on bright objects panning across the screen. Option #3 forces the player to convert 24p to 60Hz, and there aren't any noticeable artifacts, but it has the most judder. Personally, I use option 2.
To switch between 60Hz and 48Hz, you need to feed the ST50 a 24p source, then in the picture menu, there's a '24p direct-in' setting.
3. Output 60Hz
Originally Posted by Jonhern
you don't have to do anything other than set the choice you want that rahzel said, i also use option 2, and thats it, you never have to touch it again. The tv knows when it gets a 24p signal and displays according to your settings automatically. Also, you can only set the options for 24p while watching something in 24p. And you can set a separate setting for 3d as well, i set mine to 24p 60hz for regular blu rays and 24p 48hz for 3d. As per Cnet, there is less cross talk while watching 3d in 48hz. Again, once you set it once you never have to touch it again, the tv knows what type of source its getting and will use the settings for that type of source.
Thanks for the quick replies. I feel I understand these settings better now. Playing with these adjustments and experiments with my different sources did reveal differences in pic quality. By my eyesight, I think that 48 Hz looks better than 60 when sending 24p from my Oppo. Just watched both Fantastic Four movies (which have lots of fast movement and some nice outer space motion/starfields). The difference was pretty minor, but 48Hz was just a tad prettier I thought.
Also, I found a "just" setting. It's accessed by the format button. But man did that make things look fugly. "Full" looks to be my best option.
