AVS › AVS Forum › Video Components › Home Theater Computers › WMC7 + Onkyo TX-SR605 = no audio over HDMI for TV
post #1 of 17
I have been struggling to get WMC in Windows 7 64-bit in my new HTPC to output audio over HDMI to my Onkyo TX-SR605, but only TV. File playback works, and WMC startup and system sounds work.
If I connect directly to my Samsung DLP all is well.
It does not help to use a discrete ATI video card, so it's not a problem with Intel's HD3000 integrated audio/video.
If I try to setup audio in WMC7 and press the Test button, there is no sound. However, system sounds and sounds while playing a local file works fine. It's when I try Live TV with my MSI Digi Vox USB tuner, that it does not work. Sometimes there is stuttering audio/video, sometimes only video, but always, after a few seconds. WMC7 stops and displays:
I have of course tried both.
Any suggestions? I have run out of things to try.
post #2 of 17
I'm not sure if this is your problem - but with my Onkyo 705 (whicj i believe is same as the 605 in this regards) it will not play (pass through) any sound from the computer if the computer's resoultion is not set to a "TV Resoution" (like 1080 x 1920). When my computer was set to 1366x768 (the desktop resolution) I could not get sound from Onkyo. So if I was in WMC and resoultion was set to 1080p I could set sound from playing movies, but once the movie ended and resoution switched back to desktop resolution the sound won't work anymore. The WMC speaker test would not work. My computer is connected to Onkyo by HDMI cable
post #3 of 17
Hmm, thanks, but my TV is 1920x1080 and resolution is set to the same.
I am going to try a fresh install of Windows and only drivers, before trying audio in WMC7.
post #4 of 17
Finally!
Did a clean install, windows update, made sure all low level and chipset
drivers were installed. Verified Audio and Video. Went through the WMC
guide scanning channels etc and now, finally it works.
Must have been some windows odddity installation order driver problem..
Whew!
post #5 of 17
Wow, the problem came back. Suddenly WMC7 hickups after a few seconds and displays the not very helpful message: Video Error Files needed to display video are not installed or are not working correctly. Restart Windows Media Center or restart the computer".
Neither of which works, of course. I tried System Restore to a couple of days ago, but that did not help.
Then I found the problem: In Control Panel -> Sound I had (correctly) changed from Stereo speakers to 5.1. Once I changed this back to Stereo, WMC7 works fine. Even though the audio track is bitstreamed AC3 to my AVR.
So in order to get WMC7 to work, I have to set my Speaker configuration to stereo, even though it is 5.1. Makes no sense, but at least it's a workaround that's not too much hassle.
post #6 of 17
Yeah, setting it to 2.0 is the answer and it's not as bad of a hack as it sounds. It really makes no difference because if you have Dolby/DTS passthrough setup in the audio driver and the source is Dolby/DTS it'll passthrough to the receiver and be 5.1/7.1 or whatever the stream is.
This is HTPC -- finding all the little hacks to get it to actually work. It's the ... ummm... fun part ... yeah.
post #7 of 17
You are right, but I have to switch back to 5.1 when playing media files with multi-channel AAC, MP3 with Dolby Surround or other formats that can't be bitstreamed and needs to be sent as 6-channel PCM to the receiver.
post #8 of 17
That's a PITA. Stupid WMC bugs!
post #9 of 17
Yep - total PITA and been a bug in 7MC since it launched...
Really boring for those of us in Europe - where some services use 5.1 AC3 (fine with a 2.0 configuration and bitstreaming) and others use 5.1 AAC (which needs a 5.1 speaker configuration with the PC decoding to 5.1 PCM as few amps accept AAC bit streamed)
I ditched bitstreaming and leave my PC with 5.1 PCM. Which is OK - except this doesn't allow for DTS bitstreaming from DVDs in 7MC...
post #10 of 17
That's good to know now Could have saved me an OS re-install - fortunately, very quick with my new SSD HTPC. I searched the best I could for the text in the non-descript MS error, but did not find the solution anywhere. Really odd I did not find any references, since the bug must affect a lot of people. Maybe because the text contains all generic words, the search engines could not sort out the right solution.
post #11 of 17
I can usually get DD 5.1 but when I change channels I have to reset to 2.0 and then to 5.1. Yes, PITA.
post #12 of 17
Things should work if you set Windows audio to stereo and WMC audio to 5.1. Have you tried that? I have a 605 and also an 809, and I have audio working right (well, it seems right...).
post #13 of 17
Keep your settings at 5.1
In MC General Settings: Turn Off 'Play sounds when navigating Media Center'.
Video Error should go away.
post #14 of 17
... and it works! So simple, once found. Great tip. Thanks!
post #15 of 17
You are welcome!
Yes it is.
I have looked through a lot of material but nothing else seems to stick except this .
post #16 of 17
Most sub $1200 Onkyo recievers that are not the most current generation have issues with HDMI sync.
The 600, and 700 series from last couple years are terrible at HDMI sync from HTPC.
Search the forums you will see many upset owners with many issues.
post #17 of 17
You are welcome!
Yes it is.
I had this issue and after some research I found a different solution. You right-click on the sound icon in the tray, open playback devices, go into the HDMI properties, then click on the advanced tab. Then you'd uncheck the options under "Exclusive Mode".
