Cant make my mind up between the 2 screens. My room is a bat cave (or will be very soon) so I'll have complete control of light. A larger % of my viewing will be Movies and Games with the final % being 3D.
I'll be able to fit around 100" diagonal in my space. I am worried that with the 30o cone of the High Power the brightness will drop off at the edges and depending on where I am sitting will be lighter at some parts of the screen than the others ? I have a sample of the High Power and when looking face on it is pretty stunning and bright, I think that would help a lot with 3D, but again worried by the possibility of darker area's of the screen. also, anyone else not sitting in the sweet spot will find it not as bright.
The Seymour XD will be fine with viewing distances, I think it recommends 11ft or more to be perfect and to view 100" with my projector (HD33) I'll need to be more than 11ft back anyway. My worry is will it be bright enough for 3D ? Subtracting the rough 20% drop in brightness, a screen gain of 1.0 or slightly less will be lacking for 3D
Any advice is welcome
It can be maddening to decide. At times like this I do two things: start writing down the pros and cons of each; then take my time deciding. I will take a few days to process all the factors so that the stress level is low. Somehow, a good decision is distilled in the end. "Stay calm and carry on."
