AVS › AVS Forum › Audio › Receivers, Amps, and Processors › I need an inexpensive pre amp
post #1 of 8
I have a Pio Plasma and a pio blu ray player. So I think I am fine with video processing, that is if I understand the term completely, which I belive means I can assist my TV to deliver a better pic.
Having said this, are there any decent pre amps out there where I wouldn't have pay extra for great video processing or even 3D. I do not need that technology.
Ulitmately I would like something that would complement nicely both my elites.
post #2 of 8
When you mention "inexpensive".... do you have a budget in mind??
post #3 of 8
$600
post #4 of 8
This is the only one I know of south of $1500:
http://emotiva.com/umc1.shtm
From what I have read it was a very buggy unit when it was first released and I've seen conflicting reports on whether those bugs have been fully resolved.
post #5 of 8
I guess I would be better off getting an el cheapo receiver and then purchasing a seperate amp
post #6 of 8
If I may ask... what is the set up you have?? Are you running Klipsch, Polk, Meggies, B&W etc.??
post #7 of 8
What kind and how many speakers do you need to drive? You can get a Denon 3312 for $800 and have a decent amp section (and preouts), and then you could add external amplification only if you actually need it.
post #8 of 8
Problem is inexpensive receivers have eliminated Pre-outs. I went used and back a couple of years and just got a Denon 2809. HDMI 1.3, Audessy, DTS/Dolby HD formats and analog preouts for under $400 on eBay.
