Originally Posted by
NickTheGreat
The cost associated with those rooms doesn't seem to jive. There's guys on here who's theaters I would take over most of those (which cost much much less).
Oh, it definitely jives for me
. They easily have $100 K in projector and screen alone. Then add an audio system for another $100K. Then you have theater design, installation and acoustics. Say $50K for that. You have seating, carpets, etc. Another $50K. And we are up to $300K and we have not talked about all the bling, etc. Getting up to half a million is not hard at all. And if you scale up the size even more, then going up from there is not hard either.
