Originally Posted by DRaven72
I wouldn't update it if you don't see any problems with it currently. Seems issues are starting to rise with 13.06 in the 73640 thread. I haven't been back long enough to get Mits to come out and fix my 73640 since the 13.06 update. Mine was on 13.04 had no problems. Updated, got a motion blur like stutter and what looks like a spindle pushing out from center of the screen when looking off center.
If it isn't broke, don't fix it. This is really true here.
You should get a service call set up, asap... Might be a main-board problem. I don't notice any of those problems.
I even kept a watchful eye out for the stutter/judder issue... have watched several blu-rays and several HD TV shows since the update... no problems at all. Even though I did notice judder/stutter with my older 61" LCoS set, so its not as if I'd be oblivious to the issue.
I've formatted the stick 3 times now, unzipped both files onto it, nothing. TV will appear to be doing something, it will flash for about a minute and then just stop flashing. I've repeated this process about 5 times now. 13.04 to 13.05 took on the first try... messaged Mitsu, but not expecting any help
Still won't update. Awaiting response from mitsu.
