Originally Posted by
Comp625
WOW, the B652's look intriguing, especially at that price point!
B652s may sound better as surrounds than your Onkyo front speakers, but if the latter will suffice in that role for a while, then perhaps you could wait a while, learn more along the way through experience, and then decide when and how to upgrade your surrounds.
Comp625
I was mistaken about the Audyssey being Loudness Correction. The feature that is pleasing to my ears is called "Audyssey Dynamic EQ" and many HT-S3400 users have the setting at "Low" and it sounds amazing. Will buying new speakers destroy the Audyssey Dynamic EQ?
Unfortunately, I believe that the Dynamic EQ function only works in conjunction with the room correction function, so if you can't use the latter, then you can't use the former. On the other hand, you could still try it to see how it sounds for low-volume listening (who knows?).
Comp625
I tend to listen to movies/games at a lower volume. That's why the Dynamic EQ is important and having speakers that are clear in the mid's/high's are important (instead of room rattling bass).
I can't guarantee anything, but I believe that superior speakers should more than compensate.
Comp625
Alternatively, I've stumbled upon other speakers that have similar physical dimensions, but nothing seems to fit the bill. For example, Energy has a similar-sized set (can't remember the model) but I'd downgrade from a 3.25" dome to 2.5", but gain a 1" tweeter.
Am I chasing a ghost or are there higher quality speakers in a small'ish dimension?
There certainly are, and they'll sound a lot clearer, more detailed, and more "transparent" (i.e. can't tell that the sound is coming from a speaker as much), but small size still limits their capabilities. Then again, since you tend to listen at low volumes, maybe it doesn't matter as much. I still prefer to be able to cross over the subwoofer at 80 Hz, however, and most tiny "satellite" speakers, even high quality ones, don't do this well, leaving it up to the subwoofer to handle some directional sounds (should be coming from another direction and you can tell something is amiss) and even some of the dialogue, which tends to sound bad (especially with a low-end subwoofer, of course).
Comp625
So after an extra few months of using the HT-S3400 and "learning" more about home audio, I have a better grasp on the system's limitations and now have the itch to upgrade again.
Is your budget for the front speakers still $200, or has it "itched" up any since then?
Comp625
Question: The HT-S3400 speakers all feature a 1x3.25" woofer with no tweeter. Is it a
downgrade if I were to go with speakers that feature
TWO 2.5" woofer + one .5" tweeter?
Example: Polk Audio RM85
- these speakers are physically smaller but HT gurus say that size doesn't necessarily correlate with audio quality.
In overall sound quality this would hardly be a downgrade, but these are still rather small speakers that are limited in their bass capability (even upper bass). In this example, you'd actually have to raise your subwoofer crossover to 140 or 150 Hz. Some people may not mind, but I for one find anything over 100 Hz a major compromise, especially with a low-end sub, and I prefer 80 Hz or lower because for all practical purposes it keeps deep voices out of the sub.
Comp625
Space is still a constraint. The Polk Monitor 40's are very desirable BUT because of physical their size vs. the space of my Entertainment Center, it actually covers up the corners of my television (even after I wall-mount it). If I mount my television any higher to avoid the blockage, the TV is going to look funny IMO.
Wouldn't looking way upward be kind of annoying, too? Anyway, could you accommodate the shorter Polk Audio
Monitor 30 and
CS1? The total cost is $180 right now at Newegg.com.
Comp625
WOW, I overlooked those - they DO fit and they DO look awesome. 4.5" woofer with 1" tweeter in a 9" high, 5" wide, 5" deep enclosure. The reviews all seem very positive too!!
These are great-sounding speakers (like all NHTs), but they're still rather light on bass. If $300 is alright with you, these will sound better than the Polks, in my opinion. They're well balanced in tone overall (bass output notwithstanding), albeit a bit "polite" in the way of dynamics. Given the choice, I'd take them over the other options listed thus far.
Among small speakers, one that I like even more, though, is the
Ascend Acoustics HTM-200 SE. It's only a couple of inches taller than the SuperZero 2.0, and about an inch larger in both width and depth, but it has two 4" woofers, which gives it decent bass capability that holds up well in a medium-sized room at moderate volumes--you can even cross it over to the sub at the THX-recommended (and personally-recommended, for whatever that might be worth
) 80 Hz, no problem. It also sounds at least as good as the SuperZero--very detailed yet smooth in the midrange and treble, with clean bass. A set of three for the front costs $464, which is obviously significantly more than your original budget, but I thought I'd bring it up anyway because it's a relatively "big" speaker in a relatively small package (more future-proof if you ever decide to start playing them louder).
Comp625
Question 1: Can I set the SuperZero 2.0 Center speaker on its side?
I imagine that you could, but like the vast majority of speakers of this basic configuration (tweeter over midwoofer), it probably has wider, more symmetrical horizontal dispersion (important for a center speaker) when oriented vertically as intended.
The HTM-200 SE, by the way, actually works best as a center when oriented horizontally, as its close-set midwoofers and offset tweeter effectively make it a tweeter-over-midwoofer (or "T/M" as I like to call it) speaker in that orientation. The left & right front speakers can also be oriented horizontally if you wish, or vertically if you prefer (in which case there is a specific left and a specific right speaker, mirror-imaged).
Comp625
If not, I must admit that a vertical center speaker is aesthetically awkward, but it could also be years of marketing drilled into my head.
Maybe I'm biased myself because I've been using a vertically-oriented center speaker for the past several years, I'm not sure, but I do think there is a bias against them based on precedence (or marketing). OK, I get that it's not as aesthetically harmonious with the wider-than-tall TV, but on the other hand it goes very well with vertically-oriented left & right speakers, which is another way of looking at it.
Comp625
Question 2: My receiver's Crossover is set at 120hz. If I were to get these SuperZero 2.0's for the front stage (while moving my HT-S3400 fronts to the rears).
I think you forgot to ask the question.
At low volumes you could probably go as low as 90-100 Hz, but reportedly the SuperZero 2.0's bass output "runs out of gas" pretty quick. Its specifications say that it is -3 dB at 85 Hz, and I'm not questioning the measurement, but specifications alone don't always tell us everything about what a speaker can and can't do under actual use. Being close to a wall, as in your case, should help though.
Comp625
Question 3: Should I be concerned with mixing speaker impedance? The HT-S3400 rears are 6ohm, while the SuperZero 2.0's are 8ohm.
Nope, not at all.
Comp625
Question 4: Are there any other setups similar to the SuperZero 2.0 that I should consider? I'm the type that researches into all alternative options before I pull the trigger.
So am I.
There certainly are other options, but it depends on what your budget is now (if it has changed over the past couple of months), as well as how large a speaker you can or would be willing to accommodate. Sticking with the criteria I've seen so far, here are a couple of other options worth considering:
Cambridge Audio S30 - Sold only in pairs for $220, people really seem to love this speaker. At low-to-moderate volumes, there is no issue with bass on this thing, despite the small midwoofer (reportedly very punchy for a small speaker). I haven't heard it myself, but based on anecdotes I don't expect it to sound as detailed or refined as the SuperZero 2.0 or HTM-200 SE, but it has certain qualities that have earned it quite a following. The center speaker that is supposed to go with it does not seem as impressive and it costs a lot more, so it would actually be a better deal to buy two pairs ($440 total) and sell the extra speaker, or use it for some other purpose (e.g. save it for surround use in the distant future if you ever have a bigger 7.1 system, or use it as a back speaker in a 6.1 configuration).
RBH AC-51 - Long discontinued, a few new pairs are still available
here at a steep discount. The intended center speaker has a weird design, so as with the S30 (for different reasons) I'd recommend avoiding it. I don't know how this speaker sounds, but it comes from a reputable manufacturer and it's an MSRP $299/pair speaker going for $91/pair, so it probably sounds darn good for the money.
