AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Opinion: ONKYO TV-NR809 vs DENON AVR-3312CI
post #1 of 14
Hi guys.
These r the two receivers I have narrowed it down too. What are your thoughts and preferences on these? I'm torn. The onkyo has more power and I heard the denon has better sound processing? Look forward to hearing from you guys. It would be use to run a Polk rti setup(tower mains,a6 center , and bookshelf a1surrounds.)
Best,
Bryan
post #2 of 14
Originally Posted by bryanpog View Post
Hi guys.
Best,
Bryan
the denon and onkyo have the same mulieqXT so the denon no does not have better sound processing . i would choose the 809 its also cheaper and has more power and featuers only pro for denon is it has airplay
post #3 of 14
I looked at both and went with the Onk.....just had a lot more bang for the buck. If you go that route though be sure to leave enough ventilation on top....they run a bit warmer than the Denon. Either one will be great....just depends on features you want. Onk can be found for GREAT prices right now....
post #4 of 14
Where do u speak of?
post #5 of 14
I guess I'm leaning towards the onkyo. Does the denon have Pre outs for an external amp?
post #6 of 14
Yes. I went with the 3312.
post #7 of 14
It's does. Good to know. An how do u like it?
post #8 of 14
haven't hook it up yet. I have the 2312 in my main living room and love it. I was in the same boat as you, after reading posts about bad Onkyo customer service and reliability issues with Onkyo, I decided to pay more for the 3312. The Denon 3312 has 3yrs warranty v.s Onkyo 2.
post #9 of 14
Newegg has them for $699....but of course they are out of stock.
post #10 of 14
Wow that is a good price. Are u talking brand new for $699? I was looking at a refurb for $649
post #11 of 14
yes. Amazon had it brand new for $649 shipped
post #12 of 14
tvuong,
Where did you purchase your 3312?
post #13 of 14
I got my 3312 at Frys with employee price from a friend. Call Electronic Expo- they quoted me $799 shipped.
post #14 of 14
I was in the same boat as you and went with the onkyo, it just had more features and when i noticed the denon didn't have multi-channel input that was the deal breaker.
Anyways i couldn't be more happy with my purchase and everything is working great, such a power machine and you can tell when you try to pick it up out of the box.
I had a denon 2802 before this and it's night and day difference.
I wouldn't worry about all the bad reports of the onkyo i really think it's just the laws of averages.
