AVS › AVS Forum › Audio › Receivers, Amps, and Processors › R972 Trinnov User Notes
R972 Trinnov User Notes - Page 22
post #631 of 633
Originally Posted by pwiss View Post
Curt,
Does the +6db bass file add more gain to the receiver thereby needing less gain in the sub? I have a sub that has an auto on feature and was wondering if adding the +6db file would help the signal received by the sub to activate the auto on feature quicker.
While I'm not Curt, I can answer your question.. Tbe bass files change the subwoofer level, only. The +6 dB file is the same as if you turned your sub up by 6dB relative to the file labelled "flat". So it does increase the feed to the subwoofer. This could result in your being able to turn the subwoofer down or could simply make it more accurate depending, of course, on the level before.
Jeff
Gear mentioned in this thread:
post #632 of 633
Hi Curt,
If you are still around, I have a couple of questions regarding 9.1 Earlier you mentioned that in this configuration you would recommend 2 speakers be attached to each side and the rears be run in front-side (high?). Regarding the two speakers placed on each side, would it be better if one is on the side and the other is high on rear each side or is it preferable that one be on the side and the other placed on the rear for each side. I.e is it better if the second set of speakers is placed high on the rear or should it be around the same height as the side speaker.
Also, the rears that are being reoriented to the front, is it best to place them higher than the mains and to the side of them?
Thanks for any insights.
post #633 of 633
Originally Posted by Raul GS View Post
Hi Curt,
Hi Raul GS
All of this depends on what you are listening to- movies or music- and your room configuration: room shape, where are listeners, how many, etc.  The possible choices depend on many factors I believe should be taken into account. Speaker placement using Trinnov Remapping would be great seminar topic.  If you or any others would like recommendations regarding a particular configuration, I suggest you PM me.
