I'm a long time lurker who has been waiting years for a home theater, and thanks to a fairly recent home purchase it's finally going to happen. I'm going with a 2:35 screen and will be viewing almost entirely 2:35 content with some 16:9 (mostly TV series I would expect). No 3D content whatsoever.
Here is a rough sketchup of my proposed screen and seating setup:
The screen will be a drop down due to that wall being double glass doors and two windows opening up to a pool area. (Lighting control will be for another thread)
For this type of screen / seating layout what type of projectors should I be looking at? I have less than $4K budget for the projector. As I understand if you use the zoom method there will be light spilling on the top and bottom, but I'm not sure how noticeable that would be. I'm hoping that there is a PJ that doesn't spill light but I don't think it exists.
If the light spill issue isn't workable, then I believe I will be looking at some anamorphic lenses.
So far some PJs I've read about are the Panasonic AE7000, JVC X30, etc. but they all have 3D which I will never use.
I just want the screen to look as good/bright as my 40" LED TV, just a little bigger.
