AVS › AVS Forum › HDTV › Local HDTV Info and Reception › ABC KTRK Houston off the air?
post #1 of 3
I haven't picked up an OTA signal for KTRK since last Sunday. I didn't changed anything in my setup and am still receiving the other HDTV stations. I suspect my antenna on a mast may have moved slightly, but want to make sure this is an issue with my equipment before heading up a ladder to move the antenna. Thanks!
post #2 of 3
KTRK was off for me too but only for one day. Am using Hipix with no antennea movement. KTRK has a history of going blank from time to time, once for nearly two weeks as a key component broke once. I do not know why you nor I had no reception. Did you try to rescan the channel? Its channnel 32 but gets remapped via the Hipix to 13.1. Right now Notting Hill is on.
post #3 of 3
I got it back too. But my Panny STB has never remapped it 13.1, but does so for all the other channels. I suspect the signal is weaker than the others. As long as I get I don't care where the station gets mapped. Thanks for the help.
This thread is locked
