AVS › AVS Forum › Display Devices › Display Calibration › Discus and CalMan 3.6 or 3.7
post #1 of 5
I can not get the Discus to show up under the CalMan 3.6 or 3.7 select meter option. My OTC-1000 shows up and works fine.
Does the Discus only work with 4.x CalMan?
post #2 of 5
I think the Discus only works under CalMAN 4.X
RayJr
post #3 of 5
Hey DK, you know, you could have just profiled the OTC with your i1pro and got the job done today. Or doesn't the 3.x version have profiling?
You may want to post this question on the spectracal forum as well. http://www.spectracal.com/forum/inde...ea7240dae4819d
post #4 of 5
The Discuss is will only work in the 4.x line.
You can profile a meter in 3.x, but you have to create two cdf documents with gamut runs in order to get the data in.
post #5 of 5
Thanks everyone, looks like I will have to update then.
