Originally Posted by gwchoi
I just got my samsung soundbar. There is only one connecting cable between the bar (HDMI out) and my LG TV 55LM6700 (HDMI-ARC). No optical cable is used here.
Good news: HDMI-CEC works fine. I can control volume and turn on/off my soundbar with my LG remote. Yes. I can also turn ON my soundbar using my LG remote. However, it takes about 7 sec. for me to hear the sound from the bar after i see pictures on TV. This gap is mainly due to the the long booting time of the soundbar. Seeing most of the people cannot turn on the bar with TV remote, I'm satisfied anyway.
Bad news: ARC doesn't work even though I turned on ARC options(Simplink/Anynet+) on both sides. Additional cable (optical cable) solved the problem and it's just fine! But, just for my curiosity. I read many posts here that replacing the HDMI cable solved most of the ARC-related problems. But I'm using the HDMI cable that was included in the box! I believe this cable should support ARC! Before I get a new HDMI cable, I just want to ask to those who solved the ARC problem by replacing the cable. "Was your old cable included in the box?" That is, I want to know if there is any case that included HDMI cable didn't support ARC function.
What sources do you have connected and how do you have them connected?
