Originally Posted by iwb100
What I'm asking really is in your setup say, given there is an ARC source and an optical cable, if I'm watching the HD box on D-IN, will I get the sound routed from the optical cable, or from ARC? Seeing as both seem to use the D-IN source? As in will the TV still pass down the sound for the HD Box OR will the optical cable take preference in that situation?
The soundbar has an input selector that cycles through the four inputs: HDMI (for whatever is connected directly to the bar), AUX, D-IN, ARC-IN. So if one of your source devices is connected to the TV and also connected via optical to the bar, you should be able to select D-IN and get the audio from the optical even though you have ARC enabled.
Also, some source devices have an audio out setting so that you can connect to a TV via HDMI but direct the audio to optical out.
