AVS › AVS Forum › Video Components › Home Theater Computers › Reusing Old Hardware
post #1 of 9
I was just going through some old hardware and was wondering if the following would be able to work as a basic htpc for a bedroom if I added a new video card like the HIS Radeon HD 4350 512 MB
Motherboard: ECS P4ITA Socket 423
Processor: P4 1.7ghz
Memory: 1gb (4x256mb) PC800 RDRAM
post #2 of 9
Possibly. It's really light on RAM. To be honest, you may want to look at an Atom box - you're a good portion of the way there with that video card purchase, and the Atom will be faster.
post #3 of 9
$75?!?!?!?!
Do not add that card.
Honestly I would look for something on Craigslist or at a garage sale with PCI for about $50 and then add a $15 5450 card. You would come out ahead.
But the thought of either makes me cringe personally.
post #4 of 9
Why should he get an atom? You can build a SNB pentium for about $30 or so more dollars and it will blow the atom away.
I don't see the point of atom or zacate anymore.
post #5 of 9
Originally Posted by assassin View Post
$75?!?!?!?!
I did notice that the AGP cards where 4x to 5x the cost of a PCI one but I was just thinking about getting away cheaper than building a new one. But after the cost of the ram, video card, and case it's looking like it'll be close to $185 to upgrade the old hardware. Might as well add another $100 and get something worth it.
post #6 of 9
Agreed - my point was more than even the cheapest stuff out there is faster, but yeah, Sandy Bridge is so cheap, there's no reason not to.
post #7 of 9
It would work as Linux firewall or a network backup without doing much more than software.
post #8 of 9
Any word on how the new 32nm atoms are stacking up against zacate for HTPC use? I think I heard that the new atom still cant handle HD netflix streaming.
post #9 of 9
Originally Posted by tomandbeth View Post
It would work as Linux firewall ...
Except you wouldn't want an energy hog P4 on 24x7.
