AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Jamo MPA 201 amp?? Any experience with this one?
post #1 of 2
It's a 2 channel or Mono amp, and it states it does 100x2 into Stereo at 4 ohms (doesn't give an 8 ohm rating in stereo). it also says it does 200 bridged in an 8 ohm load. I was thinking about using this for my left right and using my marantz mono Block center. How does the jamo compare to the marantz? Any idea? Would this be an upgrade over my L/R center from my HK AVR 3600's power? the HK states it is 80 watts per channel, but I've been told seperates are better across the front???? Thx for any input!
post #2 of 2
