AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › returning a TV, I need some advice.
post #1 of 3
hi.
I need some advice asap. I need to return a TV because I notice a defect. The seller says I can return the defective TV but he can only give me a similar unit or pay extra to get a more expensive one. Now ive got a few question that need answering:
Which of these 2 TV consume less power?
Panasonic 42ut30 on there website has a Rated Power Consumption 270 watts, but take a look at the annual energy consumed its much lower around 177.
http://www.panasonic.co.uk/html/en_G...trackInfo=true
The Panasonic TH-L42U30 on the other hand has Rated Power Consumption 190 but for its Annual Energy Consumption of only 196.
I used the specifications for the TX-L42U3 which is almost the same as 42U30.
Strangely The plasma consumes less than the LCD i find that hard to believe. Can you trust the information from the Panasonic website?
Does the specifications mean that the plasma even consumes less energy than the lcd?
post #2 of 3
no one can offer any advice or answer some questions?
post #3 of 3
I'm not sure why you're so hung up on the power consumption on an expensive product like an HDTV.
The difference in consumption will literally be a couple of dollars per month, max.
If you're just trying to be more "green" then I'm not sure what to tell you - I'll let one of the other board members chime in.
