Hi guys. I am looking for basic video calibration help for my LCD TV. I have a 47LG50 [PDF] Been looking on the cal forums and there is a plethora of info on advanced cal. Does anyone have any links to basic calibration, ie, proper adjustment of the video settings, with links to any discs required, and the procedure? Also, I watch all my movies through a PS3. Thanks.
Featured Stories
Basic Video Cal help wanted
post #2 of 14
3/5/12 at 7:02am
- airscapes
- Trader Feedback: 0
- online
- 3,537 Posts. Joined 12/2008
- Thumbs Up: 35
- Select All Posts By This User
http://www.avsforum.com/avs-vb/showthread.php?t=948496
That is the link to the free AVS disk. It has instructions videos, as well as all the patterns for basic and advanced. There is also a user manual in that thread.
You download, burn to a standard DVD and it only plays in a BR player or PS3.
If you want to buy something instead the Disney WOW disk is very popular and directed more to someone with no knowledge of calibration or so I have read. I would suggest trying the AVS disk first and see how it goes, if use correctly it is all you need.
post #3 of 14
3/5/12 at 7:08am
- GeorgeAB
- Manufacturer
- offline
- 3,040 Posts. Joined 2/2002
- Thumbs Up: 29
The popular optical disc programs used for calibrating display systems all include tutorial instructions, either using audio narration or via text. The 'AVS HD 709' program is downloadable for free here on the forum. The 'Disney WOW' program is a good disc for beginners and includes more advance materials as well. Another good one is 'Digital Video Essentials: HD Basics,' which covers fundamental principles that the other programs lack. Be sure to check the collection of "sticky" threads in the "popular threads" section at the top of this area of the forum.
- caper_1
- offline
- 1,383 Posts. Joined 6/2009
- Thumbs Up: 15
- caper_1
- offline
- Thumbs Up: 15
post #6 of 14
3/5/12 at 6:42pm
- airscapes
- online
- Thumbs Up: 35
That depends on who you ask. Brightness and contrast from seated position with the normal average lighting you will be viewing under.
If you set brightness (dark end of the scale) up close, then go sit in your seat, you may not see any detail in the dark area because it is to dark.
Sharpness.. that is another chicken or egg.. if you can not see the hallo from your seat you won't see it in moving video. But, if you sit close you can see it and get it adjusted more precisely. Let the arguing begin!
post #7 of 14
3/5/12 at 7:52pm
- Otto Pylot
- online
- 4,853 Posts. Joined 5/2004
- Thumbs Up: 70
post #8 of 14
3/5/12 at 7:56pm
- airscapes
- online
- Thumbs Up: 35
- caper_1
- offline
- Thumbs Up: 15
lmao. nothing is "black & white" in this hobby is it? (pun intended!) Been doing all audio for last 2 years, and some of the "arguing" in that area has been going on for years.
Some of the hiccups I have run into so far with the video cal are:
The "black level" option is either low or high. When set LOW, I have a hard time seeing all the gray bars during the black level (brightness) calibration (ie, the ones below the "reference black" bar), even if I crank it to 100. All that does is make all the blacks look grayish. If I set this option to HIGH, then I can see all the gray bars during the adjustments, as in the instructional pictures and videos, and can adjust it down accordingly.
As for the color filter, I will have to get a blue filter, or maybe even get a color meter. Any suggestions on a cheap color meter for an average joe?
I was able to get the sharpness set pretty low to elilminate halo-ing (around 18).
With everything that I could set by eye, I then changed through the presets (sports, vivid, etc) and noticed that the AVC 709 help disc menu screen looked WAY different than the other modes..the background didn't even look white or as good as those "other" presets...comments?
- "backlight" feature on my TV
- "Black level" feature (low or high)
- No color filter for setting color and tint
post #10 of 14
3/6/12 at 5:44am
- airscapes
- online
- Thumbs Up: 35
With LCD you have a panel of liquid crystals that let light pass through them. The back light is just the light source that lets you see what the panel is displaying
So one way to adjust is to lower the back light for instance if the range is 0-100 set it to 30 and do the brightness and contrast. Then you adjust your backlight for eye comfort. It does not interact to much with the other picture settings. It is one of those settings that is safe to play with once everything esle is good.
Can't comment on the black level, I would set it to low. You do not want to see the bars below black, you want to see 17 a difference between 17 and 16 in the all black brightness pattern and you want to see 18-19 flashing in the the next pattern. Depending on the set you will get 2 different settings with each of these patterns, split the difference of go with the one that has bright and dark on the same screen
Set you color and tint to center default, 99.9 time out of 100 that is where it needs to be.
As to the preset, they are over blown, WAY to bright, and no where near correct and you are used to watching them.. Once you watch a properly calibrated set for a while you will not think the other looks good anymore. ;-)
- caper_1
- offline
- Thumbs Up: 15
- caper_1
- offline
- Thumbs Up: 15
Thanks, I will start with that !
When I set it low, it seems that no matter how high I change the brightness, I can't see 17 & below...everything turns brownish/gray. Adjusting it makes all the blacks brownish, and has little effect on the test pattern. Really hard to explain. If I set it high, then when I raise brightness, the test pattern works like you expect when you change the brightness levels. Again, hard to explain, but when in LOW it seems that the black it 'locked' at the right spot or somthing...
Roger that.
Yeah, everything seemed SUPER white and I noticed the levels for bright and contrast were both at 100, hah. and when I did the patterns, bright is around 89 and contrast low 50's (ish).
post #13 of 14
3/6/12 at 6:14am
- airscapes
- online
- Thumbs Up: 35
post #14 of 14
3/6/12 at 11:52am
- Phase700B
- offline
- 2,508 Posts. Joined 1/2004
- Thumbs Up: 21
that depends on who you ask. Brightness and contrast from seated position with the normal average lighting you will be viewing under.
Sharpness.. That is another chicken or egg.. If you can not see the hallo from your seat you won't see it in moving video. But, if you sit close you can see it and get it adjusted more precisely. Let the arguing begin!
Plus +1. . . . I agree, well about the depends who you ask part.
- Basic Video Cal help wanted
AVS Top Picks
Currently, there are 1954 Active Users
(539 Members and 1415 Guests)
Recent Discussions
- › SVP +1080p Animation = OMG ! 25 seconds ago
- › Official Vizio M-Series Razor Mxx1i thread 32 seconds ago
- › Does optoma have any plans for 4k? 37 seconds ago
- › Newbie questions regarding TV/Hard Drive/WiFi Setup 57 seconds ago
- › Official Samsung UNXXF7100 Owners Thread 1 minute ago
- › Runco D-73d 1 minute ago
- › Yamaha rx-a720 "official" owner's thread 1 minute ago
- › Assassin's Intel NUC Review 2 minutes ago
- › Wiring Diagram for the Remote Control of Kef Motorized Speakers... 2 minutes ago
- › Official Outlaw Owners thread 2 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Sony BDP-S5100 3D Blu-ray Disc Player with Wi-Fi by imagic
- › Yamaha Aventage Blu-ray Player Black - BD-A1020 by foursticks
- › Panasonic DMP-MST60 Smart Network Media Streaming Player with... by amesdp
- › Sonax E-0062-BF Fiji 60-Inch TV Component Bench, Ravenwood Black by DDT0C
- › OPPO BDP-93 Blu-ray Player by KingLeerUK
- › Sony Blu-ray Disc Player - BDP-S790 by wisccheese
- › Samsung BD-C6500 1080p Blu-ray Disc Player by NeonSignedOff
- › Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player by bettzysdaddy
- › Panasonic DMP-BD65 Blu-Ray Disc Player (Black) by dasher123
- › Where's The Wires, LLC Streaming Media/Soundbar Power tool by wheresthewires
View: More Reviews
New Articles
- › Why is LED light known as long life by Davidsmith001
- › Blu Ray Player Review Contest by Mike Lang
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
