AVS › AVS Forum › Audio › Receivers, Amps, and Processors › onkyo HT-RC360 wifi adapter
post #1 of 2
Hello All
I purchased the Onkyo HT-RC360 receiver and to use its net feature it offers wired and wireless connectivity. Since i can not run cables i have to go with wireless. Can any one confirm Onkyo UWF-1 works with RC-360?? Some ppl on amazon have very bad reviews about this (weak signal,drops connection,etc) and recommend TP-LINK TL-WN722N adapter (same chipset i guess).although its big and looks ugly.
What do you guys suggest.
UWF-1 or TP-LINK?? and would it work with my receiver?
Any help will be grealy appreciated.
post #2 of 2
I use the TP-LINK - works great.
Comes with a 1m Black USB extension that can
tuck under amp with white dongle/antenna in the back.
It can also be moved and adjusted for the strongest signal.
