Can Lights
I purchased 12 remodel housing 4'' magnetic transformer air tight can lights from totaldirectlighting.com. I wanted IC rated new construction cans but I had a very small space to fit the lights into the soffit and these were in my budget which was another concern. We had to place the insulation 3'' away from the housing. I have heard it said that magnetic transformers in general have less hum with dimmer switches so I am giving these a shot with my Insteon dimmers. They are compatible with MR16 bulbs so I am hoping this gives me lots of choices for beam spread, watts, etc. It would be nice to have LED lights in the theater for less heat and energy consumption but I am worried about the ability to dim the lights properly. Also concerned with the halogen lights making the fabric that I plan to put under the soffit too warm. I see it all the time here on the forums but I can't help but think it could be a fire hazard. I will just have to put them in and see how hot it gets.
Here is a pic of the cans.
Here is one of the cans after installation with the side of the soffit cut away.
I tried to space the lights out as best I could. Here is what I ended up with as seen in one of the soffits. I placed 3 lights into each of the 4 sides of the room. The 3 at the front of the room are for screen wash.
We ended up placing a screw in the cans for stability. Don't want any rattles when the Orbit Shifter does what it does.
