AVS › AVS Forum › Audio › Speakers › Best 5.1 Speaker Set with Denon 3312
post #1 of 19
Hello everyone. I have an 8 year old Polk Audio 5.1 speaker system that I pad about $500. I want to upgrade especially after buying my new receiver.
So what's good out there for $1,000? Should I go for a packaged system like the Mirage - MX 1300W 5.1 or the Energy Take Classic 5.1? or will I get better sound buying separate speakers?
I either want really small speakers or tower speakers (so no bookshelf).
post #2 of 19
Well towers would be a much better solution than satellite speakers.
How big is your room and what subwoofer do you have?
I'm guessing you want a regular horizontal center channel or can you use a tower for that too?
post #3 of 19
I am currently using the subwoofer that came in my Polk Audio package. I know towers would be better but can I get good sound under $1000 for all 5 speakers? Yes my center would be bookshelf. The room is about 15ft long 20ft wide
post #4 of 19
Jamo S606 with a Rythmik Fv12. Better than any surround package you will buy.
post #5 of 19
http://www.avsforum.com/avs-vb/gtsea...hid%3D21306746
That's a "google search avs" at the top of the screen for "best 5.1 $1000"
post #6 of 19
Ya but I want to be more specific to my needs and with my components. Speakers will sound differently based on the receiver. I want to know specifcally what the best option is for the Denon 3312
post #7 of 19
I would get the Pioneer floorstanding speakers, surrounds, and center that are on sale here:
http://www.newegg.com/Product/Produc...1&name=Pioneer
Leaves you enough for a Ryhtmik FV12 sub:
http://www.rythmikaudio.com/FV12.html
post #8 of 19
+1
That's a nice combination.
post #9 of 19
Speakers are matched to your tastes, needs, room not to the AVR. If anything it goes the other way around.
post #10 of 19
You're not going to hear the difference via a forum...and the "different" sound between different avr's is extremely subjective...
When you're using low end speakers like a Take 5 (I'm not knocking them, I have a set), it's not critical in any case as to which AVR they're connected to. For real impact, you should spend more on the speakers for better sound...
post #11 of 19
Ya so what "better" speakers would I get??? I know its all subjective but just thought I'd ask here.
post #12 of 19
Originally Posted by cel4145 View Post
+1
Really???? Pioneer speakers....?
post #13 of 19
Exactly why I'm asking here. Since I already have the denon 3312 what speakers generally sound better with it?
post #14 of 19
Would it be useful if I drew out my living room layout?
post #15 of 19
post #16 of 19
They are getting excellent reviews and testimonials. See this thread: http://www.avsforum.com/avs-vb/showthread.php?t=1278774
post #17 of 19
You'd be surprised...for their price they are damn good
post #18 of 19
And see this review of the Pioneers: http://www.hometheater.com/content/p...speaker-system
post #19 of 19
These particular Pioneer speakers were designed by a well known speaker designer, Andrew Jones. For the price point, it is a steal. Based on my recommendation, my neighbor picked up the 5.0 setup with an SVS sub and he has been ecstatic. He was skeptical too
  Back to Forum: Speakers
