EDIT: solved.. once I did this things got unstuck...
So I think it was VLC 2.0, updated something in ffmpeg, and toasted my mplayer install... I have yet to get mplayer back in shape (got video, but no audio, so I tried breaking out the big hammer, removing libavformat53 and libavformat-dev and then purging vlc2 (and its repo) in hopes of getting back to a friendlier version, but now I can't even reinstall stuff.. and coming up pretty empty on google... Ubuntu 11.10...
I've tried fix dependencies in Synpatic, but since I can't even mark smplayer for install (it gives a warning dialog about dependencies and unmarks it...
I don't even know what a "held" package is?!?!?
Code:
sudo apt-get remove libswscale-extra-2
Code:
sudo apt-get install ffmpeg forked-daapd gstreamer0.10-ffmpeg libavdevice53 libavfilter2 libavformat53 minidlna mplayer smplayer smplayer-themes smplayer-translations
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ffmpeg : Depends: libavcodec53 (>= 4:0.7.3-0ubuntu0.11.10.1) but it is not going to be installed or
libavcodec-extra-53 (>= 4:0.7.3) but it is not going to be installed
Depends: libavcodec53 (< 4:0.7.3-99) but it is not going to be installed or
libavcodec-extra-53 (< 4:0.7.3.99) but it is not going to be installed
Depends: libavutil51 (< 4:0.7.3-99) but it is not going to be installed or
libavutil-extra-51 (< 4:0.7.3.99) but 4:0.8.0.1~ppa2 is to be installed
Depends: libpostproc52 (>= 4:0.7.3-0ubuntu0.11.10.1) but it is not going to be installed or
libpostproc-extra-52 (>= 4:0.7.3) but it is not going to be installed
Depends: libpostproc52 (< 4:0.7.3-99) but it is not going to be installed or
libpostproc-extra-52 (< 4:0.7.3.99) but it is not going to be installed
Depends: libswscale2 (< 4:0.7.3-99) but it is not going to be installed or
libswscale-extra-2 (< 4:0.7.3.99) but 4:0.8.0.1~ppa2 is to be installed
forked-daapd : Depends: libavcodec53 (>= 4:0.7-1) but it is not going to be installed or
libavcodec-extra-53 (>= 4:0.7-1) but it is not going to be installed
gstreamer0.10-ffmpeg : Depends: libavcodec53 (>= 4:0.7-1) but it is not going to be installed or
Depends: libpostproc52 (>= 4:0.7-1) but it is not going to be installed or
libpostproc-extra-52 (>= 4:0.7-1) but it is not going to be installed
libavdevice53 : Depends: libavcodec53 (>= 4:0.7.3-0ubuntu0.11.10.1) but it is not going to be installed or
libavfilter2 : Depends: libavcodec53 (>= 4:0.7.3-0ubuntu0.11.10.1) but it is not going to be installed or
libavformat53 : Depends: libavcodec53 (>= 4:0.7.3-0ubuntu0.11.10.1) but it is not going to be installed or
mplayer : Depends: libavcodec53 (>= 4:0.7-1) but it is not going to be installed or
E: Unable to correct problems, you have held broken packages.
