AVS › AVS Forum › Audio › CD Players & Dedicated Music Transports › I need suggestions with CD players
I need suggestions with CD players - Page 2
post #31 of 35
http://www.vanns.com/shop/servlet/it...44/onkyo-cs445
post #32 of 35
Originally Posted by Ovation View Post
http://usa.yamaha.com/products/audio..._b/?mode=model
This will give you what you want. A friend of mine bought last year's model for his cottage. Much better sound than Bose radio. Much less expensive. It has a CD player, tuner and iPod dock built in.
Or, for an equally compact system with better sound quality, for a little more cost but still in your price range, you could get the "integrated receiver" only from that Yamaha mini-system (not the speakers) - the "integrated receiver" is sold separately as Yamaha model CRX-332:
and then order bookshelf speakers separately from an Internet-direct company that specializes in loudspeakers, such as Ascend Acoustics CBM-170:
http://www.ascendacoustics.com/pages...70/cbm170.html
The cost is $300 (Yamaha CRX-332) + $376 (Ascend CBM-170) = $676
(and yes it makes sense to spend more on the speakers than the electronics if you care about sound quality at this price level)
post #33 of 35
Similar to the Yamaha:
SC-N7 Speaker System & RCD-N7 May be what you are looking for:
http://usa.denon.com/US/Product/Page...7%28DenonNA%29
Or the Marantz version:
http://us.marantz.com/us/Products/Pa...oductId=MCR603
Leaves you $300-400 for a pair of bookshelf speakers. Denon has the SC-N7 matching speaker. They also have a bookshelf system in the $400 range comparable to the Yamaha. I'm not sure if you can find these in store, but they are available on Amazon.
post #34 of 35
Originally Posted by stevenmartin625 View Post
I was looking at the Bose wave but it is too pricey for my budget right now.
Is there any CD players that are very similar to the Bose ?
I want something that has a simple set up and a really smooth bass at a reasonable price.
I'd look at the various HTIB (Home Theatre In a Box) products, and analyze them as a player of audio CDs. That they will play audio CDs and other media is a slam dunk. I note that portable digital player interfaces are a common feature.
Google is your friend, and going to Amazon and searching on HTIB will get you a lot of alternatives.
post #35 of 35
That is a lot of budget for a CD player. Why not get a good blu-ray player for that price? Or a PS3?
