Here is my question
When dealing with a wide gamut display (which seems to be a norm now) with minor CMS flexibility..does one adjust best to 709 gamut, then at this point, you have a recalculated secondaries, then do color decoding next with revised percentages.
I see allot of people with wide gamuts, then targeting the secondaries based of a rec709 then use the standard colordecoding from rec709. This seems incorrect to me.
Am I missing something here? what is the correct way to deal with this issue.
