AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Deadline Has Been Set (and Re-Set...) Theater Build
Deadline Has Been Set (and Re-Set...) Theater Build - Page 7
post #181 of 412
Hey vanice. I went scope (2.35:1). I hooked up an old projector from work this weekend and threw in a scope movie to get a feel for the size. I was initially thinking 16:9, but now that I've seen the scope AR on the front wall it really fills up the space nice. Now I just need to get everything else ready for when the screen gets here! oh, and order the PJ, and the sub, and the receiver...
post #182 of 412
post #183 of 412
I forgot about one exciting update. Ordered the screen yesterday from Jamestown! 120" wide viewable with the SeymourAV Center Stage XD screen. Current wait time is 15 business days, so I hope it will be here by Thanksgiving...
Same screen I ordered. Might want to double-check that it's 120" wide (and not diagonal). I was given the diagonal and have since shipped it back for the 120" wide.
post #184 of 412
That sucks. I think stockmonkey2000 had the same problem. I remember discussing this exact thing with the guy from Jamestown over the phone. Hopefully he took good notes. eek.gif
post #185 of 412
That's a bummer. Hope you're ok with yours, GWCR.
Been thinking of that screen too, but then I found the Seymour (same one!) Screen Excellence Enlightor 4K screens and I think I will be going for that one instead. Will be sure to doublecheck diagonal vs. width when ordering for sure.
post #186 of 412
^^what kind of price difference and quality difference is there between the Jamestown with centerstage screen vs just getting screen from Seymour?
post #187 of 412
Originally Posted by aaustin View Post
that made my day Austin. Although to me it seems more like a mushroom cloud...
post #188 of 412
You can find the prices on Seymour's website for their screens. Based on those prices the Jamestown comes in under 1/2 the price. I can't speak for quality since I haven't received my Jamestown screen yet and have never seen a Seymour screen. The Jamestown fit in my current budget while the Seymour (and all others) would have required me to stretch it. That was the deciding factor for me. Plus I still get the Centerstage XD material which is the important part. Could have DIY'd the frame but probably wouldn't have saved enough vs. buying the Jamestown set to justify the added time and headache.
post #189 of 412
I was very specific, and he repeated back to me that it would be 120" wide viewable, but now you are making me nervous. Going to send him a quick email to verify that he has it correct.
@ tbraden32 - You can order just the XD screen material directly from Seymour and make a DIY frame. That was what I was originally going to do. After seeing the Jamestown frame, and the positive construction reviews (not necessarily timing reviews) on here, it was worth the extra $ to me to get it there. Still very reasonable in my mind. The high level would be ordering everything directly from Seymour. I considered that as well, but the savings was enough for me to stick with Jamestown. I think any of the three options are good. Just depends on what works best for you time, DIY initiative and pocketbook.
post #190 of 412
I also bought my frame from Jamestown, however I bought my Centerstage XD directly from Seymour. Saved me a little bit of money, although I did have to cut the screen tabs myself - which was pretty intimidating.
I personally thought the quality of the Jamestown screen was fine, and when pricing the materials to build my own, the Jamestown price was too good to pass up. Still performing perfectly after a few months.
post #191 of 412
I did a 120" wide screen for my theater, and was going to go with a Jamestown frame/Seymour XD screen combo. The problem started in that Jamestown is about 2 weeks out from order to shipment, and he doesn't always stock the Seymour screen material (as in my case) and Seymour was delayed a couple of weeks too. I asked if my order with Jamestown could at least get put into queue so that when the material arrived, it would get built right away, and was told "no" that it would get added to the end of the current queue of other orders. Not cool.
So i ordered the material right from Seymour, built my own frame while I was waiting, and put the fabric on the frame in about 30 minutes after it arrived. Screen was hung about 30 minutes after that (I hadn't put the z-channel up yet to hang the frame since I didn't want it in the way as I wrapped the fabric.
Hopefully you guys wil have better luck, but before you plan on watching the Thanksgiving Day Parade on a giant screen ( biggrin.gif ) I wanted you to be aware that there might be delays.
Not knocking the product at all, but just the method of how they operate.
post #192 of 412
Thanks for the feedback Brian and Nick. I was aware of the ordering to shipping time that folks on here have run into before I made my decision, so no one to blame but myself if it takes even longer than I expect. I almost pulled the trigger on it 2 weeks ago, but didn't for some reason. Oh well. If that's the only thing that prevents me from meeting my deadline, I'll be a really happy camper!
post #193 of 412
^^thanks guys for the quick responses! Sounds like lots of options depending on timing and pocketbook!
post #194 of 412
Finished wiring up the riser tonight. Tomorrow I build the steps, put the insulation in and seal 'er up. Then we'll see how far I can get with the stage...
post #195 of 412
Riser is done except for the holes for the bass trap. I don't have the register covers yet, so kept that on the to do list for now. Here's proof that I actually accomplished something over the last week.
Wiring and steps done.
Insulation in
Deck on
Stage is next...
post #196 of 412
Looks good. Is it too late to add step lights to the face of the lower steps?
post #197 of 412
Thanks Spaceman. I considered step lights on the bottom, but decided to just go with lights above the steps. I probably could still add them on the face of the steps, but I don't think they are necessary.
post #198 of 412
I also thought about lower step lights but also opted to omit them.
post #199 of 412
The flaming wallet syndrome continues. After much research and deliberation, I ordered the Onkyo TX-NR809 AVR from Amazon today. TX-NR809
This is my first new AVR in probably 8 years or so, and my first non-Sony AVR. Going to be tough waiting a few more weeks until I can fire it up.
Two more big items to go. Sub (HSU VTF-3 MK4) and projector (Panasonic PT-AE8000U). Hopefully there will be some good Black Friday-ish sales in the next few weeks...
post #200 of 412
I could use a little stage advice. I worked on the stage this weekend, and have everything done but the curve and step. This would be the "AVS Stage" design that is very popular on here. I am having trouble figuring out the depth of the step and arc of the curve. Here is what the stage looks like currently.
Here are the dimensions.
Overall width - 12'4"
Center width (between the 45's) - 7'7"
Depth of middle - 3'
Depth of sides - 4'4"
I was thinking the depth of the step and curve at the center would be 18" total. That would mean the step would protrude into the room 2" farther than the side of the stage. I could simply have the middle of the stage height curve be 9" deep and the step be 9" deep. Or go 8" and 10" respectively. Or do something else that may be suggested on here.
I have a bit of analysis paralysis at the moment, so any help is greatly appreciated.
post #201 of 412
it is easier then you think i thought it was hard at first ... here i how i did mine
start from the middle and figure out how pronounced you want the curve and take the piece of plywood your going to use and start from the middle and have someone hold it and then bend it towards the outer edge and eyeball what think will look good... then just cut the middle support and the outer end support then fill the middle it starting with long pieces working you way down maintaining the curve you wanted... then you just duplicate it for the other side
notic in mine the curve is two pieces joined in the middle
hope this helps
post #202 of 412
Thanks snickers. That makes sense. Is that 1/4" plywood that you used for the curve or thicker?
post #203 of 412
3/8 is what i used ... i think you can even go with 1/2 inch
by the way your stage looks great so far ..... check out my thread post #111 i have the jig that bigmouthindc showed all of us how to make when your ready to cut the top of your stage
also word to wise i picked up nice jig saw that makes cutting it much easier ....cheap saw makes you cut very hard ... i picked up this one and it made huge difference in my cuts
http://www.lowes.com/pd_305666-353-4495-02_0__?productId=3980317&Ntt=skil+jigsaw&pl=1&currentURL=%3FNtt%3Dskil%2Bjigsaw&facetInfo=
there is nicer ones out there but $$$ this one has served my well so far....
post #204 of 412
Thanks again. 3/8 should work. The easier the bend the better for me. I've been itchin to make that little jig, and I'm almost to that point. I'll have to re-visit your thread to get a closer look again. Thanks for the jigsaw link. I have a Black and Decker Firestorm that has worked pretty well for me. Like you said, there are plenty out there that cost more, but this one works well so far.
post #205 of 412
the one i replaced was a black and decker but it was a few years old and not the firestorm .... you will know right way when your try to make the cut smile.gif ...
keep you the good work it is looking great so far
post #206 of 412
I've had it for a couple years, and so far I've mostly gone throught 1/4"-3/4" material (plywood, MDF, OSB...). The good thing is that it's corded, so I can crank up the speed and the cuts are nice and smooth. Haven't gone through 2 layers of 1/2" yet. Better pick up a new blade for that biggrin.gif
post #207 of 412
you mean two layers of 5/8 ? top stage needs be solid as rock ..... full of sand of coarse . stage=$$$$ the money we spend to fulfill a dream smile.gif
post #208 of 412
19/32" is what I have, not sure why I said 1/2". Also not sure why they have screwy dimensions like 19/32"! I'm sure there's a reason, but 5/8 is much easier math tongue.gif
Yeah, the $$$ and the ridicule. I explained to the Mrs about the sand that would be on the way. Pretty sure she thinks I'm certifiable...
post #209 of 412
i thought the exact same thing but then you would have to say i need to some 1-1/2" x 3-1/2" instead of i need some 2x4's also tongue.gif
the Mrs has thought i was off my Rocker a few times already ...."why you using that expensive MDF can't you just use normal plywood?" ....... lol!
post #210 of 412
The fraction weirdness with the sheet goods is different from the dimensional lumber. I don't know why they make lumber those sizes, but I'm sure there's a historical reason. With the sheet goods, I'm pretty sure it's the big box stores taking advantage of DIYers. The traditional dimensions are still available, but not as easy to find outside a lumber yard or building supply company. If you're selling 15/32" instead of 1/2", you save a little on each one and the average customer thinks "that'll do." And it will do, in general - but it doesn't make it the same.
