I am setting up an audio system in my medical office and having some issues. I have five treatment rooms with one speaker each and volume controls (to turn off sound as needed) as well as three speakers in common areas without volume controls. I have a receiver (sony str-dh100) with a CD player (old, cheap sony 5 cd changer) running to an 8 way speaker selector, then running to the eight speakers. I am able to play CDs and radio but when I run a line from my computer to the receiver audio in (3.5mm stereo male to RCA) I don't get sound. This setup worked in my previous office but only four speakers and smaller office. I tried new cables and using a different computer. Am I doing something wrong or need an amp of some sort? AVS forums helped me set up an amazing home theater. Please help!
Featured Stories
Related Forum Threads
- Will the Onkyo TX-NR509 work for me? Last post on 5/3/13 at 12:49pm in Receivers, Amps, and Processors
- MAJOR issue with Panasonic PT-AR100U and Onkyo TX-nr509 Last post on 5/8/13 at 7:02am in Digital Projectors - Under $3,000 USD MSRP
- Onkyo TX-NR509 - $154.37 (New - Amazon) Last post on 3/17/13 at 5:32pm in Great Found Deals
- Is this a decent setup? Last post on 2/25/13 at 7:58pm in Receivers, Amps, and Processors
- 101 - I need help amplifying my electro static speakers! Last post on 2/13/13 at 6:13am in Receivers, Amps, and Processors
Related Reviews
medical office setup
Gear mentioned in this thread:
post #2 of 8
3/7/12 at 6:19pm
you could use a multichannel amp located near your computer and use something like casa tunes.It all depends on your budget and the type of wiring.I have 16 rooms and most of the rooms do not have speakers but they are out side in the common areas.Also depends on what purpose you want to use them for.I am a GI and am planning on showing videos for informed consent in a couple of rooms.I already have cat 6 wiring inthe rooms and plan on buying cheap amps from Parts express ,some of which cost as little as $ 30 bucks.Would be nice if we could exchange ideas.PM me if interested.
post #3 of 8
3/7/12 at 7:50pm
A word to the wise.
It depends on your square footage and how many speakers you plan on having, as well as some other factors, but you might in fact need a public performance license to play music in your office if it is going to be distributed as you describe. I'm not kidding, as much as I wish I were. I strongly urge you to consult with an attorney licensed to practice in your jurisdiction and who is familiar with the issues involved. Someone who regularly advises restaurants and bars should be familiar with the issues I am raising.
There is a dirty little secret in the music licensing business, and that's that the various trade groups (ASCAP, BMI, SESAC, et al.) routinely employ innocuous looking persons to "spy" on commercial establishments, including professionals' offices and even nursing homes, for goodness' sake, to see who might be even inadvertently infringing on their members' copyrights. When they find someone who fits the bill, they put on the shakedown in a manner that would make Tony Soprano proud. They will threaten you with the possibility of civil penalties in the tens or even hundreds of thousands of dollars and even possibly criminal penalties, but usually ultimately what they want is for you to purchase their annual musical public performance licenses.
Here's a link to a short memo another lawyer prepared (not me) briefly addressing the possible issues involved. They may or may not apply to you, but I thought you might like to know about a possible trap for the unwary. Pay particular attention to the definition of "public performance." In intellectual property law that term has a broader definition than ordinary common sense might suggest.
https://docs.google.com/viewer?a=v&q...NZOWpqv-A_LfMQ
I am only looking to run audio into the treatment rooms. I already have tv's with cable in the rooms which can also be used as a monitor to show what is on my computer in the 12 o'clock position. That is a great way to show videos and when not in use for that purpose, can be used for entertainment. So do I just hook up a multichannel amp off the receiver before the signal goes to the speaker selector? Something like this?
http://www.amazon.com/Onkyo-M-282-2-...178020&sr=1-10
Or can I bypass the computer hookup and use something like this? http://www.amazon.com/Onkyo-TX-NR509...ref=pd_sim_e_2
post #6 of 8
3/7/12 at 8:21pm
Will 2007, Thanks for the info but I am only planning on playing the radio via the internet because I am unable to get reception in the building. I will look into the issue you brought up though to see if there are any issues and figure out another music source if that is unacceptable.
You're welcome. You should be aware that even just playing songs from the radio, as innocuous as that sounds, can be deemed a "public performance" depending on the circumstances. As I said, it's a trap for the unwary. Although it might not in fact apply to your situation, what you describe raised red flags for me. If you have a regular attorney, it might be worth a call to him or her. If you do not, you might want to consider a brief consultation with one. I have no vested interest in the matter, but it troubles me to see persons possibly accidentally blunder into legal trouble, particularly when it's innocent on their part. Trust me, the music trade groups don't care if your possible infringement is innocent or not. They will shake you down nevertheless (if they learn that you might in fact be infringing on their members' copyrights via "public performance," even by playing the radio in your office so that others can hear, especially if it's essentially piped throughout your common areas).
In this case, an ounce of prevention...
EDIT: An easier way to find out if you might have a possible issue is to ask some colleagues with similar sized offices, or who might use "muzak" for their telephones while callers are on hold. You might find out that they do in fact subscribe to a music licensing service that handles all that business with the trade groups and procures for you the necessary licenses, so you don't have to do it directly yourself. Those services act as an intermediary for you, but the effect is the same; you end up purchasing a public performance license for your business. Again, YMMV, as it may not apply to you. Ask around. You may be surprised at what you find out.
post #7 of 8
3/8/12 at 12:14pm
post #8 of 8
3/8/12 at 3:31pm
You don't have to do without music altogether. There's a right way and a wrong way to have music in your business, however, unless you legitimately fall within one of the limited exemptions.
Read Muzak's explanation of the potential problem and their own solution. There are other competing services that do the same thing.
http://www.muzak.com/products/music/licensing
- medical office setup
Currently, there are 2172 Active Users
(546 Members and 1626 Guests)
Recent Discussions
- › Marantz AV8801 Preamp/Processor Official Owner's thread 14 seconds ago
- › Anyone own a Sony td hdr 30? 27 seconds ago
- › The Official Kd-34xbr960 Thread 29 seconds ago
- › Polk RTiA9 42 seconds ago
- › What are your most recent Hi-Res purchases? 55 seconds ago
- › The Official "I dont have dish or cable" anymore thread 59 seconds ago
- › Klipsch RW-12d on sale for $299 at Newegg.com again today! 2 minutes ago
- › The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's... 2 minutes ago
- › Microsoft fires the first shot in the "NEXT" generation.... 2 minutes ago
- › Emotiva amp connected to my Yamaha AVR, would this help any? 2 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
