AVS › AVS Forum › A/V Control & Automation › Home Automation › Security camera help
post #1 of 3
I've been working on my home security system and I got a really good PTZ camera, but unfortunately I can't find a user guide for it.
The camera is a v30-2030. A product document is at http://catalogs.infocommiq.com/avcat..._Datasheet.pdf .
I called the company listed on the data sheet and they are no longer in the camera business and were of little help. My problem is the camera number (Camera 10) in my case is always on screen. There has to be a way to remove this (and get into the camera settings), but I can't figure it out. It is not on the dip switches because those set camera designation and protocol.
Any help would be great.
post #2 of 3
http://www.commfront.com/RS232_Examp...Tutorial.HTM#4
Tommy
post #3 of 3
You can try to call the manufacturer of this cam
  Back to Forum: Home Automation
