I live in a townhome and I have all three floors but I have neighbors on both sides of the wall. I'm not concerned about soundproofing my stack but am concerned about noise bleeding over to my neighbors (on both sides) when I run my HT. I'm trying not to make a big mess of my current place while doing the soundproofing so doing the ceilings and tearing out existing drywall are not appealing ideas for me. I'd rather spend money to make it fast and effective.
I've read the forums but I still have questions:
1) If I just added another layer of drywall with GG on both sides, without doing anything to the ceiling, is that sufficient or do I have to do DD and GG for upstairs as well? The ceiling adds a high layer of complexity I don't want to deal with.
2) How do I dampen the sub so it doesn't shake the walls?
3) Does using quietrock and GG together get me twice the noise reduction?
4) Some of you talk about hanging the second drywall on sides and ceiling instead of attaching it to the existing drywall. How is that done with GG? I thought the idea was to use GG to stick it to the existing wall?
5) Is there a simpler way to get max noise reduction besides DD and GG? Such as pumping some material into existing drywall and sealing it up?
I'm new to this and would greatly appreciate your help.
