AVS › AVS Forum › Audio › Speakers › Big performance, small package
post #1 of 20
I am guessing this has been addressed on here before, but I could not find the right keywords when searching.
I am looking to upgrade my two fronts and center speaker, and am constrained by the 20" x 6.25" compartments in the entertainment unit. I am willing to spend about $1500 total for the three speakers. Any suggestions on the best performing speakers I should research for this situation?
Ryan
post #2 of 20
Try paradigm millennia one. Each speaker is $250, and for their size they sound wonderful.
post #3 of 20
Maybe see what NHT has that fits. They're sealed so should work better in a compartment.
Can you wall mount outside the cabinet?
post #4 of 20
Ryan
Something in the Mythos series might fit.
http://www.definitivetech.com/produc...hosSeries.aspx
Scroll down the page to the bottom.
I have no experience with them though, I am just saying some of them fit your space and price limits.
I was going to suggest the Cambridge S30 but it looks like it is a tiny bit oversized.
http://www.crutchfield.com/p_779S30D...ak.html?tp=186
Crutchfield has an awesome return policy, so there is only there is not a lot of risk.
post #5 of 20
What size is the room you're going to use them in?
post #6 of 20
To answer a couple of the previous questions:
1) I don't want to consider wall mounting outside of this unit, because my wife and I actually agree that wall mounting speakers of any size larger than a bose cube looks worse than a floor mounted speaker. I want to see if I can get the sound quality I want while maintaining the aesthetic appeal we have in the room now. I guess I feel like things should have developed far enough by now to make this a possibility.
2) Room size is 256 Square Feet, or 2048 Cubic Feet. Not a huge room. I have decent Mirage surrounds in the ceiling as well as a very capable Mirage Sub.
I also just noticed that my entertainment unit has a faceboard covering some of the enclosures. So given that I could probably do some maneuvering to get the speakers in there the realistic dimensional limits are 20"w x 7"h x 8"d. If there are good options above my price range, please let me know of those as well.
Ryan
post #7 of 20
Ryan
The PSB Imagine Mini is small and gets great reviews.
post #8 of 20
The Paradigm MilleniaOne already mentioned are very nice speakers for their size, so those are a good one to investigate. A few other worth considering are:
post #9 of 20
Ryan
You could go the custom route. Jim Salk could build you something great to fit in those spaces.
http://www.salksound.com/
BTW, you're not limited by the designs on the website, he can build just about anything.
post #10 of 20
Thanks to all for the suggestions thus far. I am thinking of going with either the Def Tech Mythos Sevens or Aperion Audio Versus Forte Centers, both in L/C/R format due to my entertainment center's three horizontal enclosure setup.
Any thoughts between the two?
post #11 of 20
to bad you could'nt squeeze 1/4" more in width or i would of recommanded the outlaw audio lcr b-stock for $475 each. 19x7.25x8.75
post #12 of 20
I'm surprised that nobody has mentioned how badly his speakers will sound shoved into a compartment. Unless the speaker is designed to fit inside your cubbyhole you will be severely hampering the quality of the sound coming from it.
post #13 of 20
Understood, it will certainly compromise the sound quality not to have the speakers out in the open, but I am trying to meet my wife in the middle on this one. She is willing to let me spend a chunk of money on speakers we certainly don't need, and so I am trying to keep the family room from looking like a rich kid's frat house with big ungainly boxes everywhere.
post #14 of 20
Sorry but please post dimensions again using this format
height x width x depth
Front ported or sealed speakers will work just fine in the cabinet.
post #15 of 20
measurements of all three cabinet enclosures: 7"h x 20"w x 8"d
post #16 of 20
Wow that is not a very big place to put a speaker.
Sorry, but I have no suggestions that will fit into that space.
post #17 of 20
It'll do more than compromise the sound. It will make it sound downright awful. Good luck, I feel for you and your dilemma!
post #18 of 20
Take a look at Anthony Gallo A'Diva or Orb Audio.
post #19 of 20
I second the Salksound tip. This one would almost fit:
http://www.salksound.com/wow1%20-%20home.htm
post #20 of 20
http://wwstereo.com/JBL/STUDIO130
These would fit and have been had for 100-120 bucks in the last few weeks
N/m .25 inches too big
  Back to Forum: Speakers
