Originally Posted by DaveC19
Easy? That sounds like a hassle to me. First you have to connect to the internet, then upload your files to a "cloud" (which has to be accesible on the PC you happen to be using), then you go to your iDevice then log on to the cloud then download the files from there with a third party app. That sounds like alot of screwing around to get a file. For one it is allot of uploading/downloading logging in etc. Plus you MUST be connected to the internet to do anything. That is not always possible if you want to use a computer other than your own. Some offices won't allow you to install iTunes or access clouds for security reasons.
To me it is much easier to jusy plug in the device directly to the computer, drag files from the directory on the computer to the device and you are done. That is as easy as copying files from one directory to another on your PC. No internet connection needed, no uploading and then downloading, no need to go through third party apps, and you don't have to sign up for and log into a special service to do things. Plus creating directory structure on the phone/tab etc the way you want it is quick and easy. If you hate cables that much I think some manufacturers allow you to access your devices through wifi as if you are directly connected.
Apple devices are still a bit too closed for my liking especially since they don't/won't give you the ability to put in a memory card for expansion. I guess that is how they force you into buying their overpriced 64GB solutions. Flash memory is cheap, they are no doubt gouging us for the higher memory capacities. I guess that is one reason they got to be one of the richest corporations around.
I guess if you like the Apple device enough it is worth it but they shouldn't make you jump through hoops to do simple things. It is like they dumbed it down so much that it got complicated.
One, we're off topic. Two, really,, read my post above yours. Three, you obviously never really used say an ipad, a cloud service like Dropbox and apps due to your interpretations above make it sound way more difficult than it is.
Bottom line, there's no logging on - its all drag and drop and completely automatic and seamless. You then tap a button on your pad of choice and your files are near instantly all in front of you, in the exact file structure you created, ready for access. You can even manage the file structure from any of your PCs or devices at will - you change it on one it changes globally.
Wifi, 3G, 4G, LTE - I'm connected every where I need to be and then some. It's completely easy, efficient and not anywhere near "screwing around". I'll take a cloud service over external storage that I have to carry around and worry about failure or loss any second of the day.
Flash and those few moments when I would like a USB port - I agree with you, and on the price gouging apple memory bit as well. Yes, 32gb jumps in memory should be no more than $30-50 vs the $100 Apple gets. But that's marketing...
Cheers
). What I meant to make clear was that 4G doesn't blow away 3G on browsing. And that's especially true here, where my 3G is pretty excellent. It seems like browser bottlenecks are not much related to bandwidth.
