Originally Posted by
Ken Ross
I've already said this and I'll say it one more time, my IPad 2 does NOT look fuzzy or anything like your 'screenshots'. The text is sharp, crisp and eminently readable.
Prove it. Press the home button and sleep button on the iPad, and it will take a PNG (losslessly compressed) screenshot, saving it to your photo roll.
Post it here. I guarantee it looks no better than anything I have posted, because that is how the iPad 1 & 2 render text. 768x1024 is not a lot of resolution, the iPad is not fast enough for subpixel font rendering, and Apple's font rendering focuses on accuracy rather than legibility.
It's far easier to disprove me by posting factual evidence rather than going on a tirade about how wrong I am, or how I am somehow manipulating things.
Well respected sites like
Anandtech have images like these of the displays:
And before you say anything, those were edited for clarity, removing the color casts and moire. (by using better downsampling methods and desaturating the images) Both images had exactly the same operations performed on them, I did nothing to exaggerate anything in the iPad 2 image.
Ken Ross
If you see fuzzy fonts on prior IPads or have difficulty reading text, may I suggest reading glasses?
Funny that you should say that, as I was just at the optician's earlier in the week. My near vision is perfect, and my distance vision remains unchanged, at +1.25 and +0.75.
I would suggest that if you
aren't noticing the massive difference between the two displays, that you should be investigating your eyesight.
If you're
happy with your iPad 1/2, then that's fine. But to say that there isn't a massive difference between the two when it comes to text rendering is factually incorrect.
Ken Ross
If my text with the material I read actually looked like what you posted without blowing it up, I would never have bought an IPad.
Those are direct screenshots from the iPad. It is exactly as the image is rendered on-screen. I don't understand why you are still arguing this point.
Ken Ross
Once again, reviews NEVER posted about 'fuzzy, difficult to read text' in prior IPads.
Text quality was mentioned in many of the original iPad reviews and glossed over with the iPad 2 as it remained unchanged. (though some reviews complained about that fact)
Ken Ross
I'm sure you'll respond with more blown up screenshots, proclamations about how fuzzy all prior IPads were compared to the new one etc. etc. etc. And guess what? When the NEW Ipad 4 comes out with even greater resolution and smoother fonts, you'll be the first to talk about how fuzzy the IPad 3 was.
I have already said that the iPad 3 doesn't have quite enough resolution to be optimal, and that going to 3072x2304 (396 PPI) would have been ideal.
If you look at the hash symbol in
this image, you can see that even 1546x2048 is not quite enough resolution for certain symbols. (it's worse with Asian characters)
However, I can't see the iPad resolution changing again, because the only option they have now is 4096x3072 which is unrealistic, and at 264 PPI, it has enough resolution that text generally does not look "fuzzy".
Toshiba has shown off a prototype display with a 498 PPI density, which does still show clear improvements to text legibility with Asian characters:
