When solid state memory is cheap enough (less than $5 for 32GB for the chip and packaging)... when, not if... the move to solid state game distribution will take over discs. When this happens, here's what your local Gamestop will look like:
There will be a wall to browse games, but it will be filled with thin OLED screens where you can swipe and tap... getting extreme detail for each game... videos.. screen shots... manuals... everything. If you decide to buy, great, you can either purchase right there for delivery to your home, or you can go to the counter and two things will happen. If they actually have the physical solid state media from the manufacturer, you'll get it. If not, you'll have the option to be given, for free, a copy of the game on a generic solid state device that they burn for you on the spot.
They'll never actually be out of stock of any game. Depending on the speed of your internet at home, it may actually be faster to go to the store to get the game since the store will contain a server that houses the games for immediate download.
In addition, perhaps ten years from now, game consoles will have 1TB+ removable solid state drives that you can download to directly to from home, or that can be brought to a physical store for immediate downloading from the server in the store. No other type of media needed at all. If you have the console, you'll have the hard drive.
! You do understand that the marketplace has only tapped about 1-5% of Blu-Ray's actual potential and lifecycle...right? It is going to be around a very-very long time. And in cheap storage capacities greater than 150gb. That is more than enough for the most ambitious game even 30 years from now in all likelihood. Some talk like Blu-Ray is obsolete right now
. MS can go DD only if it wants to. And watch XBox get clobbered by Playstation with brilliant higher-Quality Blu-Ray games. I think you are very ambitious with your SSD forecasts. But time will tell. Methinks Blu-Ray games is going nowhere but up over the next 15-30 years. And blank Blu-Rays could be just as easily copied at retail as any media. But you are opening up all kind of piracy threats with either approach.
