AVS › AVS Forum › Video Components › Home Theater Computers › Assuring 1080p at Powerup?
post #1 of 6
If my HTPC is powered on before the TV/AVR the HDMI output defaults to 480p (720x480) instead of 1080p. I don't recall having this problem in the past but then again I have just substainally updated my system.
HD 6570 (CC 12.1)-->(HDMI)-->Yamaha RX-V371-->(HDMI)-->P55VT30
Is there a (simple) way to lock in 1080p output?
(Or, is my only option to train my wife to turn the TV on first? )
Frank
post #2 of 6
I have the same setup as you but with a Vizio TV.
The Windows 8 consumer preview has fixed the 480p resolution problem for me.
I do still have the occasional loss of audio when resuming from sleep though. If I could figure that out it would be perfect.
post #3 of 6
I got around this problem by 'remoteing' into my HTPC with the receiver off and changing the display resolution to 1080p. I used splashtop remote from an iPad (set to 'use desktop resolution'). I'm not sure if VNC or other similar stuff will work too, but I haven't tried it.
The audio problem I got around by disabling all audio devices apart from HDMI. So it doesn't get stuck on anything else!
SBR
post #4 of 6
Frank
Harmony Remote?
post #5 of 6
SBR
Ahhh! Good idea - I see how that could do the trick. I use VNC on the system so I will give it a shot.
post #6 of 6
if you are running openelec or xbmc, you can force an edid.
follow my instructions here:
http://openelec.tv/forum/67-display/...start=20#21288
