AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official LG BP620/520/420/320/220 Owners Thread
Official LG BP620/520/420/320/220 Owners Thread - Page 12
post #331 of 371
The LG players aren't region-free. I don't think that they can be made region-free without modifying the hardware.
post #332 of 371
the LG BP620 there is no way to make it multiregion, unless you buy it already chipped.
post #333 of 371
After doing a lot of research and testing, I found out the blu ray player can handle 7.1 through USB. The audio has to be DTS 7.1 (dolby true HD 7.1 doesn't work don't know why). All you have to do is mux the usual MKV file into a m2ts container with TS muxer. Looks like the mkv container is limited to 5.1 whereas the m2ts (native blu ray file type) is more flexible with that kind of thing,
So for everyone of you that has a 7.1 system and want to take advantage of the USB playback, try that little trick and you'll have the full 7.1 surround sound instead of 5.1.
Cheers!
post #334 of 371
hi guys i got a big problem ! i got LG bp420 3d blu ray player , 1 week ago all was ok and working fine , then i moved to new house , since im in new house one of my computer always get network error while playing a movie and i have to restart all , but with my other computer all work fine ... all is up to date and was working fine 1 week ago , and now it only work fine with one of my computer
any idea ?
thanks
edit: it alway bug and say network error afther 40 min of playing , if i restart it it bug again afther aroun 40 min of playing
i really need help please that annoying
Edited by Marcel LHeureux - 7/8/13 at 1:05pm
post #335 of 371
Regarding the LG BPx20 series of players -
I have read several messages here reporting locking, hanging, and crashing back to the splash screen. I assume this is due to filesystem corruption, and I have wanted to get deeper access to the player through UART in order to correct it. The entire x20 series uses the same main board and processor (MediaTek MT8551), so I thought finding the schematics would be easy enough. I have looked everywhere with no luck. Does anyone know how to get a serial/UART/TTL interface with this series of players?
Steven
post #336 of 371
LG pb420b - surround sound over HDMI?
Does anyone know how to get surround sound over HDMI with this player. I cannot seem to find a passthrough setting. I'd rather not use a toslink connection as I do not have any free on my receiver.
post #337 of 371
How is your equipment run?
S~
post #338 of 371
New firmware:
BD9.681.00.00.C
post #339 of 371
Anyone have any idea what the new firmware does aside from bug fixes?
post #340 of 371
I have an issue with my player (BP220). When connected to USB, all the video is ever so slightly choppy. Enough to make it exceedingly irritating. Its almost like it plays at 20fps instead of 30fps. Video DVDs play fine - No issue with the low frame rates. I tried different USB flash drives, and USB hard drives, and they all seem slightly choppy. I even burned one of those video files to a DVD, and it was fine. So obviously the issue is with the USB transfer rate?? Any suggestions would be appreciated
post #341 of 371
I've noticed the same thing with all mp4 files. Mkv files play OK. I transcode all mp4 files on the fly through DLNA using Universal Media Server. That's the only way I can get mp4 files play OK.
post #342 of 371
Hey Guys,
i have a BP420 .
Can i come to the Servicemenu ?
Can i modify to play ISO Files ?
Can i hack the firmware zu enable additional features
greetz
post #343 of 371
HI
I just picked up a BP620 on sale. I have read there are a lot of variation in firmware. I was wandering is there is anyone with a compilation of older firmware versions. that way if there is a problem one could revert back. perhaps even someone with developer experience we can combine the best of all version. If i could get a handful of older version i would see what i can do.
post #344 of 371
I'm French and I have a BP 420 since last year.
I use it to play with a HDD External or usb key. It work fine.
I often use the Youtube service with smart TV premium.
I didn't used my tv for a few months.
Since last Week, I decided to play some videos on Youtube.
An update is requierd BD9.593.00.
So I downloaded it on my usb key and installed it on my bluray drive.
I checked in the BP420 settings and the software is BD9.593.00.
But when I want to open Youtube, it stills demand me to update and it doesn't work, Contact customer service message.
Any hint?
post #345 of 371
Installs the new fimware: BD9.681.00.00.C
post #346 of 371
didn't find it on lg website in bp420 directory
post #347 of 371
Settings/ [OTHERS] menu /Software/Update
post #348 of 371
On French portal, only BD9.593.00 is available.
UK same version.
Can you post the link?
post #349 of 371
Settings in Blu Ray player.
post #350 of 371
This error
post #351 of 371
I used to own a LG BD 570 and it practically played everything I threw at it.
Last month I gave it to my parents and got the LG BP 620 instead. I have a problem though. Whenever I stream files from my laptop OR play them from a USB flash drive I can't rewind them. When I press rewind on the remote it starts rewinding for maybe 2 seconds and then jumps right to the start of the file. The next big problem is I can't fast forward or more like I can't skip to a certain point in the movie/file. It takes forever! It seems to me that the player needs to buffer all the data up to that point before it can play from that point.
My BD570 did it flawlessly though. When I skipped to the end of a file it did it almost instantly. What gives?
post #352 of 371
The same problem on bp 420 but it depends on the file format.
post #353 of 371
Hello to all.
I have had the LG BD660 player and recently I have bought the BP620. Is there any difference in these players at all?
I know BP620 has wifi and wifi direct, besides that, is there any good reason to keep BP620?
I have done some testing of mp4 SD and mkv HD, and it seems to me, that BD660 is better in picture quality...
I was hoping that BP620 could play HD youtube videos, but it does not and there is no way to switch it to HD. BD660 is not able to do this as well.
Do you know of any comparison or testing regarding picture quality of these 2 players?
Thanx to all.
Martin
post #354 of 371
This thread isn't the most active but it's worth a shot. Anyway my BP620C won't connect to my network anymore. Some times it doesn't show any networks at all but then it will. I'll click on my network then enter the password. I get the little spinning thing for about 20 seconds then it ask for the password again. If I enter it again it just does the same thing over and over.
I called LG since it's just under the year warranty. Get this, for that model the warranty is a year but the labor is only 90 days. They told me the minimum labor charge would be $75. I politely declined. Anyway, has anyone had this problem or is the wifi on the player simply out. The Blu-ray player downstairs and every other wifi device works fine.
post #355 of 371
Try to verify your network setup.
post #356 of 371
I have a LG BP620N and after i updated to the latest firmware my mkv-files started to develope some weird artefacts. It's like that small detail in the picture starts flickering when the camera moves. For example a persons hair get's a wavy pattern when the camera moves. It's also very noticeable on horizontal lines in the picure. Looks like some kind of anti-alliasing problem. Anyone else expering the same issue???
post #357 of 371
I have also noticed that the problem only occurs with 720p mkv files,not with 1080p mkv files or upscaling dvd...
post #358 of 371
Is that via USB or streamed? I've been streaming to the player via Plex and have not had any issues with 720p or 1080p. I have not tried USB.
post #359 of 371
Is there any possibility to get the Netflix App on BP420 in Europe working? DNS Change doesnt work. I can only switch between Europe Regions without UK.
Edit/
After updating my german BP420 to newest Firmware. I set up my DNS, changed Region to Netherland, and now the Netflix app is there. It seems like i can watch the US Netflix Stuff.
Edited by nvihero - 1/8/14 at 10:27am
post #360 of 371
New firmware smile.gif:
BD9.707.00.00.C
