Hello Everyone,
Since I have a plasma, I want to create my own windowed test patterns to see if a smaller window size provides better results. I have a very basic question that I hope someone can help me answer.
When creating the patterns, can I use the 0-255 RGB range, or do I need to keep colors between 16-235? Does the encoding process convert the 0-255 values to 16-235? I plan to use the process outlined by alluringreality in the following post:
http://www.avsforum.com/avs-vb/showt...4#post16837914
0-255 makes the 10% IRE steps a lot easier. I can simply leave Hue and Sat at 0%, and add 10% to Brightness. If I need to use 16-235, I need to figure out the most accurate way to increase the steps. Should I simply add 22 point to RGB for each 10% step?
