AVS › AVS Forum › Video Components › Video Processors › Darbee vision darblet
Darbee vision darblet - Page 66
post #1951 of 6132
Originally Posted by lovingdvd View Post
My new Darbee with the updated code to work with the Lumagen in YCrCb 4:2:2 arrived today and I just finished testing it. It has software version: 2.8.2214 and Firmware version 1.3.21. I can confirm that this works with the Lumagen now in both RGB and YCrCb 4:2:2 without color issues.
However... unfortunately this has now introduced a side effect in the HDMI handshaking. Specifically when running in 4:2:2 mode with my Comcast STB there is a full screen flash of magenta when I change channels which involve a resolution change. For instance when I go between a channel that is 720p to a channel that is 1080i, or vice-versa. When doing so the channel change is now rather messy with this bright magenta full-screen flash. I put the Radiance into RGB mode and the magenta flash does not happen. I put it back into 4:2:2 and it happens. Just to make sure that the Darbee was involved, I removed the Darbee from the chain and retested the channel changes. Without the Darbee in the chain the channel changes involving a resolution change are perfectly clean - black during the brief transition, no flickering, no magenta. I put the Darbee back in and once again confirmed the messy channel changes and magenta flash. I worked extensively with Lumagen several months ago to help them test firmware that ultimately gave us these clean channel changes so I'm not so thrilled to see this issue introduced. Maybe it's something Lumagen can tweak in their firmware to compensate, I'm not sure. The channel changes with the magenta flash are rather bothersome, so much so that I may just run in RGB mode for now until this gets resolved. It may also be specific to my chain and projector. For reference I'm going Comcast DCX-3400 -> 6 foot HDMI -> Lumagen XS -> 6 foot HDMI ->Darbee -> 50 foot HDMI -> Sony VW95 projector.
I reported this to Larry at Darbee as well as Lumagen support. All this said I still love the Darbee and would never consider getting rid of it even with these issues here in the early days.
Sorry to hear you're running into this. I thought you can only specify either YCbCr 4:4:4 or RGB on your STB. Maybe it's been updated...
I guess with my luck (TIVO HD which outputs YCbCr 4:4:4) I'm not seeing these types of issues, though there is quite a bit of back and forth flickering on the screen, sometimes seeing a burst of green rather than magenta. But I fully expected that the EDID negotiation would have that result. Certainly glad I'm not much of a channel surfer...
post #1952 of 6132
It will try it just as a test the next chance I get and will report back the findings. However I'm not keen to run it this way even if it works. Lumagen does all its processing in 4:2:2 and there's a chance the VW95 natively uses 4:2:2 itself. If that's the case then what you suggest would result in the Lumagen converting it to 4:4:4 and then the VW95 just converting it back to 4:2:2. I believe the general advice from Lumagen is to output in 4:2:2 and let the display convert it to what it wants.
Well, its quite possible this falls more into the Lumagen camp then the Darbee camp, in which case I would anticipate a firmware update for the Radiance to clean it up.
Yea but the Darbee does its processing in 4:4:4 so it is taking the 4:2:2 from the Lumagen and converting it to 4:4:4 for processing then converting it back to 4:2:2 for output. It's a question of which way works better in a given system.
post #1953 of 6132
Originally Posted by henrich3 View Post
You can configure the Radiance to output whatever resolution & color space you want, regardless of the input resolution/color space. If you configure the Radiance to convert 720p/RGB to 1080p60/YCbCr then the Darblet should never see an input resolution of 720p or a color space of RGB. If your Radiance is already configured to scale 720p to 1080p but it just misses the first few frames, try configuring your Comcast box to output 720p content as 1080i. The Lumagen should do a better job of scaling however.
I'm not saying that Darbee support shouldn't investigate this, but hard-coding the Radiance to only output 1080p and 4:2:2 should hopefully resolve any resolution change or color space change related issues.
This is probably more about the Comcast color space settings and the associated Lumagen input setting for that specific input. The Comcast can either be set, unless there's been a change to firmware function, to either 4:4:4 or RGB. So, choosing one of these it would make sense to set the Lumagen's input to the same. Setting the Lumagen input to 4:2:2 would result in a mismatch. The other thing that's going on here, seems to be a resolution change. He didn't say which one is set on the Comcast. I think the default is 1080i though you can specify others. And there's another interesting setting that allows you to select the native mode operation. Not clear to me just how that impacts the way the Comcast presents to downstream, though I'm thinking that specifying 1080i here allows for 4:4:4 color space.
I can confirm that when I output Native from my Tivo HD that I too see a magenta flash whenever channels having differing resolution (i.e. 720p to 1080i) but not when switching to channels from the same resolution. Last about 1/10 of a second I think.
Edited by sjschaff - 8/8/12 at 10:08am
post #1954 of 6132
Normally you would want to choose native and have the Lumagen do the upscaling as it is the superior video processor. What brand of boxes does Comcast use?
post #1955 of 6132
Has this actually been established, that the D processes in 444?    Where did you find out about this?
post #1956 of 6132
It's in the manual
post #1957 of 6132
I am not well informed on the visual impact, if any, in using 4:2:2 versus 4:4:4 but it seems that work is going to get done along the way, no matter which is chosen. In my case, since the chain is Tivo HD (sends only 4:4:4), Lumagen input side 4:4:4, Darblet 4:4:4 and finally JVC 4:4:4 that would keep processing in the color space to a minimum with the Lumagen and JVC doing work. As you suggest, using 4:2:2 for Lumagen and JVC puts the onus on the Darblet and off of the JVC. I guess I should try this, at least to see if EDID speeds up in syncing all of the components. But I've not idea on how this will affect the image. Do you?
post #1958 of 6132
I get similar behavior from my Duo with Comcast box set to native. Not magenta, but when changing to a channel with a different resolution, there are a couple of screen flashes between the content and all black before the picture stabilizes. Switching between channels with the same resultion is quick and smooth.
post #1959 of 6132
I`m interested in buying the Darbee Darblet, where can i order this online that ships to Sweden?
post #1960 of 6132
Go here and fill out your question https://shop.avscience.com/crm.asp?action=contactus
There are other potential dealers as well http://darbeevision.com/#dealers
post #1961 of 6132
A member here who lives in Australia ordered his thru Smarthome. If they ship down under, there's a good chance they ship to Europe too. Send them an email and me some baked apples.wink.gif
post #1962 of 6132
I don't believe AVscience ships internationally.
post #1963 of 6132
Ok, i did send them a question. Will look into the other dealers as well.
post #1964 of 6132
post #1965 of 6132
Folks! Get a copy of the Spears and Munsil disc and test each color space to see what is best. 4:2:2 into my JVC RS1 is not good so don't just go by what somebody else says you should use. You have to see it for yourself.
post #1966 of 6132
Darbee working just fine with my Motorola DCX3400 DVR (aside from the colorspace issue with known Darbee bug for Lumagen users). I used to have the 3416 box. If the DCX3400 is available in your area IMO its a much better box and your hard drive capacity will be a lot more. I think I went from like 160GB to 500GB when I upgraded my DVR to the 3400.
Comcast brought me a DCX3400 box today and it too flashes the picture and audio in and out when run through the Pioneer TXH-94 receiver to the Darbee and on to the projector. It would put a picture straight through from the Comcast box to the projector. So no change in status here with cable TV. My HDMI cables are 10' into and 25' out of the Darbee.
I hope a solution can be found....Football season is around the corner.
post #1967 of 6132
I received mine and am very happy with the results. I use mine on an Epson 6010 and I like it around 58 for gaming and 48 for Sat. I haven't messed around with Blu-Ray or 3D yet. Once I get it all figured out I will program a macro on my MX-6000 so I never have to touch the unit. smile.gif
post #1968 of 6132
Is there a way to change a Samsung LED television to receive RGB over one of it's HDMI inputs (like a PJ) as opposed to native Ycrbr? Otherwise, I think the color will be off no matter what I put as the output (RGB or Ycrbr) of each individual player.
post #1969 of 6132
It's in the manual
Yep, you're right!    Thanks, I had missed that.
SO, since one might expect the Lumagen to do the color space conversions better than any other component, it might very well be best to send 444 out of the Lumagen to the Darb.     Still better to do what Ronomy advises, i.e., check out all possibilities with the M&S disk.
post #1970 of 6132
At this point we don't know why some people, who have a Darbee with the latest software, connected to the Radiance, are sometime seeing some flashes of color when the resolution changes. We doubt that this is caused by the Radiance, but we will try to get a Darbee with the latest software, to check it's operation with the Radiance. Often we can do something in the Radiance to help with this type of issue.
Randy Freeman
Lumagen
post #1971 of 6132
See.....tsk...tsk....I think they do like each other.... big smiles for "their" futures.....biggrin.gif
post #1972 of 6132
Randy Freeman
Lumagen
What a great company!
post #1973 of 6132
Agreed!
post #1974 of 6132
Randy Freeman
Lumagen
Randy: thanks. I think I'll wait to hear what Lumagen has to say before sending my Darbee in for an update.
post #1975 of 6132
Yes, the manual does state 4:4:4 but that was before the colorspace firmware change wasn't it?
Dr Darbee...could you please complete this matrix:
Code:
Input Colorspace       Internal Processing Colorspace    Output Colorspace(s)
YCrCb 4:2:2                          ??                          ??
YCrCb 4:4:4                          ??                          ??
RGB 16-235                           ??                          ??
RGB 0-255                            ??                          ??
Edited by Geof - 8/8/12 at 5:04pm
post #1976 of 6132
I did not mean to imply what I am sending 4:2:2 from the STB. As you and others have mentioned, the only options are RGB and 444. So I have 444 going from my STB to the Lumagen. I do not tell the Lumagen what the input is so it figures it out on its own I presume. I only tell it what to output.
Lumagen spent a lot of time several months ago optimizing their HDMI handshaking especially related to resolution changes. I did a lot of testing for them and the result was fantastic. They got it cleaned up and very tight. With the Darbee in the chain and 422 set it is now messy with the magenta flash. Whether this is more on the Lumagen or Darbee end I couldn't say. All I know is that its clean without the Darbee in the chain.
I am using the Native option on the STB. Yes exactly - changing to a channel that uses a different resolution results in the flash. Changing channels within the same resolution is smooth and very fast.
I do not have this disc, but am curious what the procedure is for using it to test this specifically. Can you explain?
So then does the Darbee note whatever the color space is on the way in, do its processing in 444 regardless, and then convert back to the original space? So if it comes in via the Lumagen at 4:2:2 the Darbee then converts it to 444, does it work, then converts it back to 422, then the projector gets it and may very well convert it back to 444 (anyone know what the Sony VW95 does)? With this in mind then perhaps it is better to output 444 from the Radiance regardless of the magenta issue. At any rate I'll try it and will let you guys know if it still flashes magenta in 444.
post #1977 of 6132
### Well it seems with the Tivo HD - Lumagen XS - Darblet - JVC RS35 I'm having the same magenta issue as you. Interesting...(we'll leave it to Randy and his team to puzzle this one out).
### I have the disc and if you go to their site for this article http://www.spearsandmunsil.com/articles/choosingacolorspace.html you'll see it's a lengthy process. I went through it with the Darblet active in the chain at HD level 50 testing 4:2:2 and 4:4:4 with the Lumagen and JVC and saw no visible difference, to my tired eyes. So, I don't think it really seems to matter whether the Darblet or the JVC is doing the work of converting (Darblet to 4:2:2 or JVC to 4:4:4).
### Looking forward to hearing what your testing uncovers on the flashing issue. I was under the impression that you get a single magenta flash and then everything works. Others seem to have a sync / flashing problem that seems never to settle. Hope I'm understanding that correctly.
post #1978 of 6132
My flash is just a single bright full screen magenta flash that last a fraction of a second, then is fine until the next time I change the channel to one that uses a different resolution than the one I am on.
post #1979 of 6132
I'm truly speculating, but seems like the following might be preferred:
the Comcast dvr sends out 444 (passed through an AVR) to the Radiance, which converts it to 422 and does its work, then converts back to 444 and send this to the Darblet, which now has to do no conversions since it works in 444, sending 444 on to the projector.    So all the conversions are done by the Radiance, and none by the Darblet.
Agree that it would be nice to know whether the Sony 95 (and 1000) has any preference for the color space it receives.
post #1980 of 6132
This is from a 2007 AVS thread on the JVC RS1:
gregr - "The projector's internal processing uses YCbCr signals (as do virtually all projectors and video processors). Therefore, the projector must convert incoming RGB signals to YCbCr, process them in YCbCr, and then convert them back to RGB to drive the LCoS panels. It is the RGB-to-YCbCr and YCbCr-to-RGB conversions that provide the opportunity to use mixed (Rec 601 and Rec 709) conversion matrices.
It looks like going into the JVC with YCbCr will save one conversion but the YCbCr-to-RGB conversion at the panel will always take place.
The ideal bit rate of the incoming YCbCr will be another matter. I believe incoming RGB is always 8bit.
Does anyone know if the conversion scheme has changed for the newer projectors?
  Back to Forum: Video Processors
