AVS › AVS Forum › Video Components › Video Processors › Darbee vision darblet
Darbee vision darblet - Page 71
post #2101 of 6306
I have installed the Barbee by using duct tape (kind of spirit of Red Green) alongside the cabinet just below the projector, with of course the sensor facing the screen, and the Barbee remote works without fail by pointing it at my screen. Its convenient and I don't have to worry about an extender.
When viewing my leftover dvds I use the pop at about 45. Seems to add quite a bit of punch to the contrast, etc.
post #2102 of 6306
post #2103 of 6306
HAHAHA. I thought it was a typo at first but then the second one rolled around.
post #2104 of 6306
Originally Posted by tkbryant View Post
post #2105 of 6306
Originally Posted by dolphinc View Post
Yea. Especially concerned about the duct tape...
post #2106 of 6306
I finally found an IR extender that is working just fine with the Darbee. It's here: http://www.amazon.com/gp/product/B002JSDHCY/ref=oh_details_o04_s00_i00. No external power just a straight plug in to the IR socket on the front of the Darbee. Working fine with my URC MX-700 which I am using after learning the IR codes from the Darbee remote. Sensor has an adhesive back which I have used to situate on the bottom front of my Pio plasma.
post #2107 of 6306
Originally Posted by giomania View Post
Sorry, for the OT post, but its Friday!
I was wondering what you all thought of using this non-adhesive window tint film to manually turn down the brightness of the LED's on my Monoprice HDMI switches? They do not have an internal adjustment option, and they are pretty bright. I have put electrical tape over them in the past, but was looking for a more elegant solution.
http://www.amazon.com/Gila-JS246-Static-Control-Automotive/dp/B00062YZXU
Thanks for any input.
Mark
I use these http://lightdims.com/store.htm?PHPSESSID=4cba871b7361a6eb558e45436f9c5de2 which I also use on other electronics I own with bright LEDs. No cutting needed since they come in different sizes/shapes.
post #2108 of 6306
For what its worth, my cell phone is kaput and the provider won't have a new free replacement for me until Tuesday aft. All calls to my cell or to me through the AVS number are being switched to my home phone 301 570 7617.
If Franz Maupus is listening, please send me an email at mark@avscience.com. The email address we have for your Darblet order is bouncing. Thanks
post #2109 of 6306
Mark, I understand that you favorite hookers at CEDIA wil now be calling your home to make sure you are coming to CES! Once your wife answers the phone, you will feel like a shrimp on a Darbee!@@
post #2110 of 6306
Originally Posted by DIY Guy View Post
UPDATE:
I was having sync trouble with my Comcast Motorola DCH3200 interacting with the Darblet. I went to Comcast and swapped it out with a MOT DCX3400 and tried it out with my updated Darblet and was disappointed to find it was still not working 100%. It seems that the STB still reports a HDCP authentication failure. The screen reports a warning, then will put up a green screen while still passing through the audio. I tried the Darblet just after the STB, after the AVR and finally at the projector with no change. So back to Comcast to try a Cisco STB, if no joy, then component and SPDIF set up.
FYI
I came across this CEDIA - HDMI seminar that I found helpful. You can check it out below. Many case studies from AVS Forum smile.gif
6-QuantumData-CEDIA_Seminar_[Compatibility_Mode].pdf 2159k .pdf file
Post Edit:
Exchanged the DCX-3400 for a Pace RNG110 and I now have everything working properly. The Darblet is placed after the AVR and before the Projector. biggrin.gif
Good read.
So the answer as to my issue of Comcast HDDVR's flashing in and out, according to this, is replace the set top box. I've been through two different ones so far. Comcast is going to LOVE me before this is over!
Do you concur Dr. Darbee?
post #2111 of 6306
I see differences in Software but the Firmware is the same, what is the difference and should I be worried?? Some have Software 2.8.2214 and others have 2.8.2205, but the Firmware number is the same 1.3.21.
post #2112 of 6306
For those who are understandably skeptical, just remember the saying: If something looks too good to be true, it probably is a Darbee. biggrin.gif
Seriously though, put in Toy Story. So cool! The wood floors just got a new polishing. All the toys are brand new and shiny again.
I too find that if you pause the video to look at what the Darblet does it's not as impressive a seeing what it does to the entire viewing experience. Also just focusing on one small part of the image doesn't tell the whole story. I like to slightly defocus my eyes so that I can see what the Darblet is doing across the entire image.
post #2113 of 6306
Toy Story! Now I have to go check it out...I bought all 3 on bluray but have not watched the first movie in a long time. Do you have the 3D version too? I don't.
I agree the Darblet is amazing!
post #2114 of 6306
Fine... I'll answer my own question. LOL.
Blu Ray: I've got a modest setup. Still using a 720p LCD projector. Settled on using the Darbee (for now) at HD-60% setting. Full-pop is cool, but for Blu-ray, I prefer the more blended effect that HD gives.
All I can say is "wow"!!! This $260 device just added a few more years to my Panny PT-AX200's lifespan. (Wife very happy with that.)
Watched Sherlock Holmes: A Game of Shadows, Star Trek, and HTTYD. In all cases the image just jumps out at you with increased depth and detail. (Wonder how the actors feel about their wrinkles getting the Darbee treatment.) The Darbee makes my aging $1000 projector look like a $10,000 projector (or what I'd hope such a projector would look like if I could ever afford one.)
DVD: Used Full-pop for DVD, also at 60%. Watched parts of LOTR: The Return of the King, The Big Red One, and the DVD version of HTTYD - decently mastered DVDs.
The effect is much more subtle with DVD than Blu-ray. Still, considering the limitations of the source material, the Darbee definitely improved the image, especially at the foreground level. I'm using an Oppo DV-981-HD (again, older technology) and blowing the image up to 180" diagonal at 2.35:1 against a satin-painted wall. Gives a nice level of enhancement to the image, but certainly lacking the dramatic "wow" factor of Blu-ray. Nonetheless, I'm very happy with the improvement.
Anyone with a similar "po-boy" setup like mine should definitely consider the Darbee.
One question to the Darbee folks: Is unplugging the Darblet between uses recommended? I noticed the device remains a bit warm when plugged in. Want to maximize its lifespan.
post #2115 of 6306
Originally Posted by TikiBar View Post
Anxiously awaiting my Darblet. Just wondering how it handles DVD material.
In addition to my Panny BD35, I'm running an Oppo DV-981 DVD player into an Onkyo TX-NR708 receiver and out to my Panny PT-AX200u projector onto a rather large wall. Haven't made the jump to 1080p yet, but I'm hoping the Darblet will give my current system a nice (and inexpensive) boost.
... my original post.
post #2116 of 6306
Yes I have all 3 Toy Stories in 3d. These movies were made for Darbee. I did see some artifacts when I used either game or full pop but it might just be bringing out some imperfections in the source.
post #2117 of 6306
Self adhesive Velcro is your friend.
post #2118 of 6306
Originally Posted by Jive Turkey View Post
I mentioned earlier that Terminator Salvation was a good test for the Darbee, and your shots show it.
Another good one is to get the full screen head shot of Christian Bale in "Batman Begins" early in the film when he's grubby. When you switch to the Darbee on HiDef at 50%, hairs on his facial scrub show up that you can't see without it!
But the director did not intend for you to see those details.
Edited by 42Plasmaman - 8/10/12 at 7:58pm
post #2119 of 6306
LMAO!!! I'll have to say I have never seen that one before!! That's awesome!
I watched "Book of Eli" tonight and man I was blown away with how good that film looks "Darbee-ized". This lil box just continues to amaze.
post #2120 of 6306
I am so glad that person does not post in here anymore. I guess he finally realized what he was saying, without actually seeing a Darbee in action, was not vey bright.
post #2121 of 6306
He moved over to the Blu-ray forums & attempted the same thing....it was a no go there too.
post #2122 of 6306
Thanks for the link. I just ordered the 3-pack (no more cutting black electricians tape!smile.gif)
post #2123 of 6306
That is a shame. It is almost like trying to convince people that TV is bad for you because it frys your brain.
post #2124 of 6306
post #2125 of 6306
Clealry not a problem for those not having a brain.
Edited by AV Science Sales 4 - 8/11/12 at 9:58am
post #2126 of 6306
Me too! Thanks for the link....ordered the three pack.
post #2127 of 6306
I have a roll of car window tint that I use for this. Works great. Sometimes need to double it up tho.
post #2128 of 6306
Problem with Darbee IR reception in 3D mode
I have a problem with the IR reception while my VW95 is in 3D mode. The Darbee does not recognize any IR commands from my normal seated distance of about 15 feet to where the Darbee is located. I have to get within about 3 feet of the Darbee for it to recognize the commands. At first I thought it may have been the remote because it is so tiny (credit card style remote) that I wondered if it had enough power. So I learned its commands into my Home Theater Master MX-700, but it behaves exactly the same way. Clearly the IR flooding the room from the projector's 3D sync is somehow preventing the Darbee from getting a signal. However none of my other equipment located right by the Darbee has any issues with IR reception in 3D mode. So I wonder whether the IR receiver used in the Darbee is strong enough or can be improved. Has any one else used the Darbee in 3D mode with a Sony projector and had the remote working from this distance? Note that I do not have any issues with IR reception when not in 3D mode (it actually is very receptive in non-3D, never have to press a key twice etc).
post #2129 of 6306
I have a problem with the IR receiption while my VW95 is in 3D mode. The Darbee does not recognize any IR commands from my normal seated distance of about 15 feet to where the Darbee is located. I have to get within about 3 feet of the Darbee for it to recognize the commands. At first I thought it may have been the remote because it is so tiny (credit card style remote) that I wondered if it had enough power. So I learned its commands into my Home Theater Master MX-700, but it behaves exactly the same way. Clearly the IR flooding the room from the projector's 3D sync is somehow preventing the Darbee from getting a signal. However none of my other equipment located right by the Darbee has any issues with IR reception in 3D mode. So I wonder whether the IR receiver used in the Darbee is strong enough or can be improved. Has any one else used the Darbee in 3D mode with a Sony projector and had the remote working from this distance?
I have an ir blaster setup to control equipment in my projector room. I avoided the ir 3D glasses just for this reason. Went with the RF glasses instead.
post #2130 of 6306
Just ordered a three pack. I have so much duct tape in my system it isn't even funny. Thanks for this!
  Back to Forum: Video Processors
