I'm sure you'll be very happy with it. Zombie's pictures a few posts back are representative of what it can do. My set-and-forget setting is HD 40%. The Darbee Off setting looks a bit out of focus compared to having it on. Let us know what you think after you've had a chance to play with it.
Featured Stories
Related Forum Threads
- IR Receiver for LG LST-4600A Last post on 2/23/12 at 6:52am in HDTV Technical
- Using a remote to control zone 2 Last post on 5/17/11 at 10:58am in Receivers, Amps, and Processors
- Verizon Fios Motorola 7232 Last post on 1/20/13 at 3:24pm in HDTV Recorders
- The **Official** Denon 3311CI/ 991 Owner's Thread NO PRICE TALK Last post on 6/14/13 at 9:18pm in Receivers, Amps, and Processors
- The "Official" Pioneer VSX-1019AH Owner's Thread Last post on 6/16/13 at 3:18pm in Receivers, Amps, and Processors
Related Reviews
Darbee vision darblet - Page 79
Gear mentioned in this thread:
- buzzard767
- Trader Feedback: 0
- offline
- 2,896 Posts. Joined 12/2005
- Thumbs Up: 86
- Select All Posts By This User
- dreaux
- offline
- 870 Posts. Joined 5/2006
- Thumbs Up: 15
I am running a Yamaha RX-A2010 ...to Darbee ....to an Elite PRO-70X5. Seem to see more difference with a higher quality sources like Blu-ray. In this case LOTR. On Directv HD not as much. I suppose I can increase the Darbee effect with that.
Is anyone running the Darbee with a DVDO iScan Duo? I am thinking of getting one and am curious if it worth the money to go that route.
- Josh Z
- Cranky Member
- offline
- 18,652 Posts. Joined 7/2002
- Thumbs Up: 54
I understand that screenshots don't tell the whole story, but if he is using the same camera settings and taking one picture after the other you would think that the way the image on the screen looks to the eye would be duplicated by the camera. Or at least the camera wouldn't change the way her face looks from one shot to the next if he took 2 pictures of the identical image. If so then he is changing a setting in the camera or not standing at the same distance from one shot to the next. It may not change the colors, but the contrast is definitely changed based on those shots.
You don't take a lot of photos, do you? Any number of factors could cause the two shots to come out differently. Perhaps he took them a few minutes apart and the light in the room changed? Perhaps his camera caught an odd reflection in one shot but not the other? Perhaps it's not a very good camera and has an inconsistent CMD sensor?
This thread is filled with hundreds of user reports that confirm that the Darblet does not change the color values in the image. You can choose to listen to all of us who've actually used the product not, but basing your objection solely on some photos that were taken by pointing a camera at the screen is only doing yourself a disservice.
- sjschaff
- offline
- 375 Posts. Joined 4/2004
- Thumbs Up: 13
I have used the Darbee for a few days now , I have to say I am very happy with my purchase.
Honestly, $260 to improve perceived pic quality by my estimate 10 to 30%, depending on the source, is probably the best bargain that I ever got in my theater.
Think about it, if you shop and find the best $3000,00 PJ that you can buy, how much better would the best $3500 pj be? Probably a slight incremental improvement at best.
It is normally a dimishing return on investment. In most technology it is this way.
A company like Monster Cable for instance was built on the concept of trying to make whatever electronc purchase you made perform better. People spend a lot of money on cables ect. to try to make their $2000. system perform like the $5000 system they would have bought if they could have afforded it. In most cases there is probably little or no perceivable difference with new cables over any other decent and less expensive one. Not including any placebo effect
When I went from a DLP pj to my JVC, I did so because I decided that deeper blacks were more important to me than the higher sharpness and pop the the DLP had.
I was happy with the JVC on the whole even with that trade-off . I am not saying that I did not miss those attributes of the DLP, I did, but the blacks were just more important to me.
Darbee has closed the gap in sharpness and pop for me, I can now have my cake and eat it too!
If you can get this at the original price, do so now! If you have to pay the new price, do so now, it is still a great purchase!
Tony.
I've used CRT and DLP and then LCD in the past, and finally did LCOS first with Sony Ruby and now with JVC. I agree with your assessment. As others have noted, it seems less about sharpness and more about making the image more three dimensional. And I've found, as have others, the better the source material the more you can take from the algorithm. On the other hand, the older, though well transferred, material cannot be pushed too far - old B&W especially suffers from too much Darbee. I can go with a 50 Full Pop with over the air HDTV if well produced. The kind of jump in apparent "performance" is sort of like my recent experience doubling memory and replacing my boot disk with an SSD. Makes an older system really fly.
- tolax
- offline
- 277 Posts. Joined 1/2006
- Thumbs Up: 11
Picture on the HD Cable seems a little soft and of course you have the joys of Comcast HD compression being highlighted on the big screen
I was thinking of putting the Darbee on the link between the Denon and Plasma but searching shows several people having issues with the Comcast handshaking.
Any views on whether this is going to work/show an improvement on the cable signal (and yes I appreciate I'm trying to create a silk purse from a sow's ear)
Tolax
- Robert Clark
- offline
- 4,111 Posts. Joined 6/2000
- Thumbs Up: 11
- Jay5298
- offline
- 215 Posts. Joined 2/2007
- Thumbs Up: 10
Just trying to be objective, and gather as much information as I can before I decide to buy one of these.
- Ronomy
- offline
- 3,001 Posts. Joined 8/2004
- Thumbs Up: 13
Dude just buy one and be happy! The result is amazing...order one before the price goes up and be happy! I ordered a second for my 3D projector...they are that amazing!
- dreaux
- offline
- Thumbs Up: 15
The photos on post #2283 are an excellent example of what the Darbee does. There is no color shift, just a change in detail/sharpness.
I am using the Darbee. Got mine from Solid Signal. They had 22 left, not sure now though.
- buzzard767
- offline
- Thumbs Up: 86
- jwv651
- offline
- 5,527 Posts. Joined 1/2004
- Thumbs Up: 10
- AV Science Sales 4
- AV Science Sales
- offline
- 1,440 Posts. Joined 7/2011
- Thumbs Up: 17
- jwv651
- offline
- Thumbs Up: 10
- BrolicBeast
- Trader Feedback: +4
- 1080pROFESSIONAL
- offline
- 1,408 Posts. Joined 9/2009
- Thumbs Up: 51
- millerwill
- offline
- 10,875 Posts. Joined 4/2004
- Thumbs Up: 11
Had eye surgery last week but am now somewhat back in action. (My updated Darb came back from Darbee several days ago but am just now able to check it out.)
First, my config: Sources (Comcast dvr, or Sony 790 BD player) => Onk 3008 AVR (pass through) => RadianceMini => Darb => Sony 1000ES pj.
Second, as l'dvd first reported, I see the magenta flashes when I change between SD and HD channels (but not between 720p and 1080i HD channels) if I output 444 or 422 from the Radiance to the Darb. If I output RGB from the Radiance to the Darb, there are no magenta flashes and the switching is much smoother and quicker.
Since the latest info is that the Darb's internal working is in RGB--and since I can't perceive any PQ difference between send 444, 422, or RGB out of the Radiance--I've settled on sending RGB out from it. This way only the Radiance has to do color space conversions, and the Darb presumably has to do none. The Sony pj seems able to be able to accept any color space with equal (to my eye) PQ.
- WiFi-Spy
- 3D Addict
- offline
- 2,256 Posts. Joined 2/2004
- Thumbs Up: 13
Just got my Darbee yesterday and am quite happy with it. I seem to prefer HD at 55%. Adding more tends to make the picture have some hard edges and is not really improving the picture IMO.
I am running the Darbee between my DVDO Duo and my Plasma.
- dreaux
- offline
- Thumbs Up: 15
But does the DVDO Duo make an improvement?
Right right now I am running from my Yamaha AVR HDMI to the Darbee HDMI to my Elite Pro 70. What I was trying to figure out is if it is worth getting an additional VP like the DVDO duo to add to the video chain. Or is having just the Darbee alone in the video chain enough?
Would the difference in image quality be only negligible and therefore the DVDO not really worth the bang for the buck.
The VP in the Elite Pro 70 is quite good. But after seeing the Darbee I am wondering if there is even more I can tweak.
Edited by dreaux - 8/18/12 at 6:36pm
- Jive Turkey
- offline
- 1,394 Posts. Joined 6/2002
- Thumbs Up: 10
Can anyone confirm if the Comcast issue is resolved? My chain is Motorola DCH3416 (Comcast) or Revo 3600 (XBMC) or Sony S590 (Blu-ray) -->HDMI-->Denon 2312-->HDMI-->60GT50 Panasonic Plasma.
Tolax
I haven't heard any further word on what's being done to make it work with Comcast HD DVR's through receivers, a Pioneer THX-94 in my case. I took my DVR into the bedroom for now, as I'm not taking the Darbee out of my Bluray, HDDVD, HD D-Theater system. It's made my VW60 projector look like an upscale performer.
- millerwill
- offline
- Thumbs Up: 11
As noted above, I use my Comcast HD DVR, through an Onkyo 3008 AVR (pass through), to a Radiance, to Darblet, to projector (Sony1000), with no problems.
- Jay5298
- offline
- Thumbs Up: 10
Okay fine! One last question, are the units sold by amazon the new ones with the fixed color space issues?
- Ronomy
- offline
- Thumbs Up: 13
Unless your TV and or AVR has crappy scaling and deinterlacing and the color is over saturated on your TV requiring a color management system to fix it then you don't need a VP like a Duo or Lumagen. The AVR should give you the switching you need. Some of us have separate audio and video chains and we require switching of analog and digital video so we require VP's like this. I only got the Duo so I could correct the colors on my projector and required switching. The Duo has a lot of HDMI ports and analog video as well.
- Ronomy
- offline
- Thumbs Up: 13
- zombie10k
- JVC RS55 -> 142" HP
- online
- 5,737 Posts. Joined 12/2007
- Thumbs Up: 72
none of the above.
folks have to read my post a little closer.
these are examples of the RS55 + Darbee with e-shift OFF and ON, clearly noted in each screen description. There are 4 'seating distance' photos of the girl, not 5. The 4th photo is boldly marked at 70% darbee. Of course it looks cooked. The point of including this photo - a pro-review site felt it was necessary to crank the Darbee to 'show' the readers how it looks. If someone knows how to take a 1/2 decent screen, it's quite easy to show the difference between the Darbee OFF vs. Darbee @ a moderate 30-35%.
FYI - No room lighting changes, photos taken within seconds of one another with just a single variable being changed between shots, all manual exposures w/ remote trigger. The Nikon D90 sensor is quite consistence between frames as I've demonstrated in the 3D mini-shootout thread.
none if this changes the fact that it still needs to be seen in person to judge if one likes it or not.
- AV Science Sales
- offline
- Thumbs Up: 17
You don't need anything. You can eliminate most everything and clearly above whatever $X one wants to specify anything more is not worth the bang for the buck.
Until you had a Lumagen for as many years as I have had and with numerous free upgrades and improvements many out there simply have no clue as to how it can be used to improve ones PQ on let's say very economic systems to top of the line high quality stuff. If it were a simple either or choice, I would have to pick the Lumagen over any one function processor but fortunately I don't have to choose. Almost every scaler out there for taking 720p to 1080p rings like a jewler beset by 10,000 women who just got engaged. Most deinterlacers are not designed to give the option of increased lines used for detail over sacrificial lines to achieve less comb filtering artifacts. Not to mention the very very soon coming ability to calibrate over 125 color points instead of the six color points plus black and white that we have currently used for calibration to what will imminently become an archaic way of calibrating. Look for the very soon to be immediate releases by Chromapure and Spectracal to employ the 125 point CMS targets that will be generated by the Lumagens and calibrated through automation. What's it gonna cost? Free by Lumagen and probably a $50 upgrade fee by Chromapure.
As to the question of whether the store on Amazon is offering the latest firmware, my guess would be yes or they would have done an Amazon offering far earlier. Of course maybe it doesn't have the Lumagen fix, just depends on exactly when they were shipped their order, but I am sure someone can call Dareevision to see exactly what that company got. And thanks to those who continue to support AVS by ordering them from us for Mid September shipment.
- xplorar
- offline
- 118 Posts. Joined 11/2006
- Thumbs Up: 10
- buzzard767
- offline
- Thumbs Up: 86
Ohhh. Cat's out of the bag. I knew they were up to something. 1D or 3D LUTs?
Only 13 left....
Edited by buzzard767 - 8/19/12 at 6:15am
- xplorar
- offline
- Thumbs Up: 10
- rothsss
- offline
- 22 Posts. Joined 11/2004
- Thumbs Up: 10
- gene9p
- Trader Feedback: +1
- HIGH END ONLY!
- offline
- 1,221 Posts. Joined 4/2006
- Thumbs Up: 20
- Darbee vision darblet
Recent Discussions
- › Samsung F7100 vs Sony W802A - Movies/TV & Video Games 37 seconds ago
- › Difference between 2.0 using surround decode, 5.1 with EXTD... 41 seconds ago
- › The Official Xbox One thread... 41 seconds ago
- › Official Panasonic VT50 owners thread 1 minute ago
- › "Official" Audyssey thread (FAQ in post #1) 1 minute ago
- › Hot Off The Press: The Latest TV News and Information 1 minute ago
- › Why is it always possible to distinguish "real" sound from... 2 minutes ago
- › PlayStation 4 2 minutes ago
- › Looking for LCD/LED's that are Full Array and have Local Dimming 2 minutes ago
- › The Last of Us - Spoiler-ific Discussion Zone 2 minutes ago
Recent Reviews
- › Sony BDP-S5100 3D Blu-ray Disc Player with Wi-Fi by imagic
- › Yamaha Aventage Blu-ray Player Black - BD-A1020 by foursticks
- › Panasonic DMP-MST60 Smart Network Media Streaming Player with... by amesdp
- › Sonax E-0062-BF Fiji 60-Inch TV Component Bench, Ravenwood Black by DDT0C
- › OPPO BDP-93 Blu-ray Player by KingLeerUK
- › Sony Blu-ray Disc Player - BDP-S790 by wisccheese
- › Samsung BD-C6500 1080p Blu-ray Disc Player by NeonSignedOff
- › Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player by bettzysdaddy
- › Panasonic DMP-BD65 Blu-Ray Disc Player (Black) by dasher123
- › Where's The Wires, LLC Streaming Media/Soundbar Power tool by wheresthewires
New Articles
- › Why is LED light known as long life by Davidsmith001
- › Blu Ray Player Review Contest by Mike Lang
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
