AVS › AVS Forum › Video Components › Video Processors › Darbee vision darblet
Darbee vision darblet - Page 157
post #4681 of 7863
Originally Posted by poster View Post
I just ordered one with the nice discount from Solid Signal. I would have ordered from AVS, but the lower price point was too hard to pass up. Hoping I will like the product, paired with my JVC DLA HD-250.
You basically have an RS10. I have an RS20 and the results are pretty amazing. I 'set and forget' at GAME MODE 50%. I use gaming because it seems to enhance even more contrast, without introducing any negative artifacts......
post #4682 of 7863
I have a darblet on the way. Is anyone here using this gadget with a Pioneer 141FD?
post #4683 of 7863
Originally Posted by roknrol View Post
Solid Signal is a good retailer. I've ordered many things from them in the past (antennas, coax connectors, and such). I received my Darblet from AVS during the promotional pricing period, though. The discount code plus Solid Signal's current sale price gets you the same as the promotional pricing period from this summer.
I thought Solid Signal used to be forum sponsors, but maybe that's changed.
I "wasted" a few $'s on shipping, never realized I work just a few miles from these guys!
http://www.solidsignal.com/p/?p=2595&d=about-us
Signal Group LLC
SolidSignal.com
SolidSignal.tv
25225 Regency Drive
Novi, MI 48375
We do offer walk-in retail services at our location.
Pickup times must be scheduled by phone. Available pickup times occur Monday thru Friday, 8:00 AM - 5:00 PM. Customer pickup service is for U.S. residents only.
post #4684 of 7863
Have the oppotunity to buy a used darblet darbee but the seller doesn t know which version it is. How do I check which version it is? (there are more versions correct? what are the differences between the versions?)
post #4685 of 7863
Right now it's not the 'versions'...it's all about the firmware/software update that you have to send in for...other than that, everything is the same..........
PS In my opinion, I don't think there will be any difference in the 'real world'.....unless you have more video processors that do 4 4 4
post #4686 of 7863
I m using madVR on a HTPC as renderer. You know if I will need the latest firmware? How do I check which firmware is on the Darbee?
post #4687 of 7863
Menu-->About
Firmware and software versions can be read from this menu page.
Newest versions are:
Software version:2.8.2214
Firmware version: 1.3.21
-DD
post #4688 of 7863
Getting mine today.
post #4689 of 7863
Got it. It was working fine until I went into my Anthem settings menu to adjust my subs then when I exited I had a purple screen. I had to turn off my Oppo , Anthem, and TV. Picture was ok when I turned them all back on.
post #4690 of 7863
Got mine yesterday. After messing about (thanks to a crappy hdmi cable) I watched about an hour of Avatar on Blu-ray. Big difference in sharpness. Will continue to play around but so far and excellent piece of equipment.
post #4691 of 7863
What causes the sparkles?
post #4692 of 7863
Bad HDMI cable
post #4693 of 7863
Originally Posted by David Susilo View Post
Bad HDMI cable
My guess too. Had to replace one a few weeks ago. Hadn't touch the connections for a long time and the HDMI cable just seemed to give up. Screen looked like a starry night.
post #4694 of 7863
Bad HDMI cable
Grrrr. I am using brand new Blue Jeans high speed HDMI cables.
post #4695 of 7863
I am using Blue Jeans cables as well, with no issues.  Given that you had an earlier problem with the purple screen, there may be something else going on.
post #4696 of 7863
Maybe a setting among the devices.....
Anyhoo, first impressions:
Definitely a difference. More so in Blu Ray than in DirecTv. After fiddling with it I left it at 50% HD for a happy medium. Gonna live with it a few days for a final verdict.
post #4697 of 7863
What effectively is the difference between Gaming at 40% and HD at 40%?
post #4698 of 7863
There is some difference to do with which areas of the picture are effected I believe. There may be a more detailed explanation elsewhere on this thread, but it's hard to search as it's multiple terms. Basically HD should be less intrusive in terms of side effects.
post #4699 of 7863
Originally Posted by englechgc View Post
I'd like to use it with Verizon fios, but it would be hard persuading the gf to let me purchase another Darbee. I have a Monoprice HDMI switcher that I'm not using. I'm thinking of feeding the switcher from the BR player and Verizon fios receiver to the Darbee then to the splitter and on to the projector and TV.1.gif
I have my Fios, and 2 blu ray players going into Monoprice HDMI switcher..then to Darbee input and out to TV..for my projector ,I just unplug the tv lead from the Darbee out and plug in my Projector's hdmi. I guess a splitter after the Darbee would be ok and easier.
post #4700 of 7863
That can not be answered in words to make any sense. Just look at a paused picture, especially a facial close up and you will see the difference. Ditto full pop.
post #4701 of 7863
Lol. Ok.
post #4702 of 7863
In the two professional reviews that I have read (Gary Reber's in Widescreen Review and Kris Derring in Home Theater Mag), there is no mention of what is going on behind the scenes with the three modes.  Both reviewers opine that Game Mode seems to work best with gaming sources (as expected), and that HD Mode provides the most pleasing result.  Most feedback on this thread indicates that what mode is used is a matter of taste.
post #4703 of 7863
From earlier posts:
Depth cues can be interpreted as artifacts. HD mode provides the hardest clamps on depth cue "artifacts" and is the result of 18 months of feedback from other companies. Gaming mode was created by releasing some of the clamps we use in Hi Def mode. For CGI and gaming content, the image is often clean and can take more depth information. Gamers also want the depth cues as they indicate that it helps them perform and win more.
Use judicious amounts of DVP, Full Pop in low 30-60 settings or Hi Def or Gaming Mode 40-80. Hi Def and Gaming Modes you have noise/artifact detectors engaged and you will have a wide range of settings to play with, or set and forget just below a level that you feel causes some artifacts to creep through.
Hope this helps...
post #4704 of 7863
post #4705 of 7863
Originally Posted by xplorar View Post
Just before projector is recommended but most people (including myself) have it just after receiver.
I have mine before the receiver.
HDMI Distribution & Switching Diagram.pdf 985k .pdf file
Mark
post #4706 of 7863
Mark
Yea, Mark, you have a typical setup....  ;)
post #4707 of 7863
GAMING MODE is the brother of HD MODE. POP MODE is the cousin of GAME AND HD MODE.....that's how Mr. Darbee puts it.....
post #4708 of 7863
I hate it when PHD's throw around these heavy scientific terms....
post #4709 of 7863
Are Gaming Mode and HD Mode brother and sister? And I'm wondering about the cousin.
I'm asking because putting two Darbees in series, as some apparently are doing, might be incestuous and therefore illegal.
Or...you might be a Redneck if you have two Darbees in series.
Edited by karlsch - 11/16/12 at 7:39pm
post #4710 of 7863
ADVANCED MODE
Now that we have that part of the modes figured out, is anyone willing to admit to being brave/anal enough for advanced mode -> fine, where you can make adjustments in 1% increments?
Frankly, 5% is precise enough for me.
  Back to Forum: Video Processors
