I've searched Dr. Darbee's posts and the closest response I can find to the 4:4:4 /4:2:2 issue is this response:
Originally Posted by JAKEMON
Originally Posted by DarbeeDr
I have answered this a couple of times, mostly for those interested in video gaming and audio sync.
Another way to put the answer is this:
The HDMI 1.4 spec demands 165 MHz for 1080p/60fps, or put another way, allows 165,000,000 ops/sec.
Since we pass a (10bit/color channel) pixel to the output within this specification, we are putting pixels (first in, first out) across our circuit with a total latency of 3 microseconds.
The latency is inconsequential for any human factors of perception for image or audio, even for video gaming.
-DD[/quote
Hello DD. My setup is OPPO BDP-95 to Kuro 141FD using HD Base-T hdmi over cat 6 Beldin Mediatwist. this allows me to utilize the 12bit pixel depth Deep Color setting on the OPPO and Kuro.
will this present a problem using the Darbee Darblet since it only passes a 10 bit output?
Here is the response from our engineer:
"This should not be an issue. The Darblet will accept the 12-bit input, reduce it to 10-bit internally, and then after processing kick the signal back up to 12-bit for output. This means that, when Darbee is OFF, the output will not _exactly_ match the input signal, but the difference will of course imperceptible."
-DD
I don't believe this implies that the Darbee processes internally at RGB - anyone else have any info on this question?
though some displays might give better results, in general the deepcolour settings on many devices just add exttra zeros so they are purely 'padding' rather than extra 'detail'.
