Originally Posted by
p5browne
Might I ask - How much heat is there on top of that projector? I have my Darbee heat sinked top and bottom to keep it cool!
The heat up the near to the ceiling, add what the Darbee creates, plus what the projector is producing must make it a bad scenario re cooling!
A good question, as can be seen my PJ is open, not in a hush box, the PJ heat vents are on the front, the darblet is at the rear,
There is no "bad scenario" for cooling at all, however being fact based I'll use my IR therometer and post those for sharing.
The better question is:
What are the darblet's DFMEA and DVP&R related to thermal loads, heat cycle testing, etc.
How is it designed for "normal" usage in peoples HT?
What assumptions went into the relability of the design? What thermal values does it expect to see?
On the re-set issue:
What software DFMEA and DVP&R and debugging was done to ensure the re-set did not happen?
What fix can be pushed to people in the field?
