AVS › AVS Forum › Video Components › Video Processors › Darbee vision darblet
Darbee vision darblet - Page 202
post #6031 of 7863
Originally Posted by gweempose View Post
Imagine when they start filming TV shows in 4K. It could put a lot of actors out of work. biggrin.gif
post #6032 of 7863
Hello gentlemen and ladies,
I re-did my setup over the weekend when I upgraded a Denon 4311CI and a Oppo 103 to my system. One of my goals was to place the Darblet on the back of my display between the upright of the TV mount and the back of the display. It fits perfectly in that area with no need for any use of attachment like Velcro or the like. The front of the Darbee at the new location faces the front wall of my room. I thought I was going to have to run an IR emitter to the Darbee on the back of the TV but to my amazement the Harmony One that has the Darbee codes works without the use of an emitter. My theory is the Harmony sends out such a strong IR signal that the commands for the Darbee are bouncing off the front wall and hitting the Darbee's IR receiver. Very happy with this discovery. biggrin.gif
post #6033 of 7863
It's amazing how IR signals can bounce all over the place. I had to run an emitter to my Darbee, because it is hidden away in my cabinet.
post #6034 of 7863
I'm thinking the same.. My Darbee is in my cabinet (open) but not in view, it's actually quite hidden in the back of my PS3. Harmony One commands for it somehow always work on first or second push, not bad at all, need to hide that ugly thing anyways tongue.gif
post #6035 of 7863
Edited by hometheatergeek - 5/6/13 at 10:55am
post #6036 of 7863
If Darbee wants to learn how to make a nice looking device, they need to attend the Roku school of design. Roku makes small, slick little devices that anyone would be proud to display in their A/V rack.
post #6037 of 7863
I think they only want to make a chip and sell it to TV/AVR/BD/etc manufacturers, and not actually have any end user devices. They just needed to get it out there in a stand alone format so people would notice, and start asking for it, imo
I agree about Roku designs.. And Algolith used to make some really nice looking video processing equipment.. Too bad they're long gone frown.gif
post #6038 of 7863
Interesting how differently people think about home theater. All my equipment is hidden away in a projection booth. The speakers are hidden behind an AT screen. Nuthin' but the show, man... so how equipment looks doesn't matter in the least. The Darbee is great just the way it is.
post #6039 of 7863
Originally Posted by JewDaddy View Post
I too have a projector that I'm using my Darbee with. Just curious what setting both of you have yours on. HD, Game or Full Pop? Thanks
HD 60%
Curious, how do you add the Darblet to the Harmony One? In the Logitech remote software, I'm stuck at what type of device to add. Thanks.
Edited by Coach KG - 5/6/13 at 11:31am
post #6040 of 7863
Originally Posted by Coach KG View Post
HD 60%
Type of device = video switch. It should show up as DarbeeVision DVP-5000, but I renamed it "Darblet" for my Harmony 880.
post #6041 of 7863
HD 60%
Video Switch is what you're looking for, then the full name with model #..
post #6042 of 7863
Found it, thanks to you both.
post #6043 of 7863
Is that a joke or were you being serious?
post #6044 of 7863
I was actually being dead serious about the Roku. In terms of design, I think they nailed it. It's small. It's black. And unlike the Darbee, all its connectors are located on the back side. It's both simple and elegant. smile.gif
post #6045 of 7863
Hi all,
I will be picking up my Darblet today from the post office and I had a question re hookup. The Drablet comes with a 6ft HDMI cable thrown in by the seller and I just want to be sure I get it hooked up right. I've searched this thread (and other sites) and think I have to do it this way:
4 sources>Kinivo HDMI switch>6ft regular HDMI cable>Darblet>30ft Redmere cable (oriented correctly) to Epson 8350 projector.
Would this be correct?
post #6046 of 7863
Originally Posted by Alexdad54 View Post
Hi all,
Looks good to me. It's generally best to put the Darbee in-line right before the display, just like you described.
post #6047 of 7863
Hi all,
Should be fine, however I did have an issue with my Kinivo, and ended up swapping it out for a monoprice 3x1 enhanced. Hopefully you won't have an issue.
post #6048 of 7863
Thanks for all the feedback. Re the Kinivo, I actually got it because I had issues with my previous Monoprice HDMI switch (I also discovered it was only 1080i) so hopefully this will work.
Do you have a catalog # for the Monoprice enhanced switch in case I have to get that. although I hope that won't be necessary because I'm getting too much gear stacking up in the cupboard! tongue.gif
post #6049 of 7863
Pred1073, with your room size and Epson id think you would be looking at bigger screen, just my opinion.....bigger is better smile.gif
Sent from my 32GB iPhone4 using Tapatalk
post #6050 of 7863
Originally Posted by pred1973 View Post
Theater room isn't finished yet, but is 16x18 with 8 foot ceilings, will be painted dark grey/red/grey projecting onto 106" Elunevision Reference 4K Studio screen. Thanks.
Sorry to be the second post to not answer your question, but mtbdudex is completely right. I have a 16x21 foot room and my 10' wide 16:9 screen is none too big. My first row is at 10' and my second row is at 16'. I'm very glad it's no smaller for sure. It looks superb from the front row with the Darblet.
post #6051 of 7863
My room is 38x16. When I put in the theater room I wanted to go a minimum of 120". But was talked out of it. You can guess by who.wink.gif. Every time I went down there I was disappointed. So after 3 yrs of that I decided to do it my way. I now have the biggest screen I could go with and still have an awesome picture. What size you ask, 159 inches! My projector is a Mitsubishi HC6800. I agree with the previous posters, I would go as big as I can and still have a great picture because in the long run you'll be disappointed if you don't.
post #6052 of 7863
The monoprice switch I'm using is here, http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=8462&seq=1&format=2
It has a touch sensitive switch, which is kinda cool I guess, and auto detects the active source every time, so far. The led was way to bright, requiring me to put some electrical tape over it, to tone it down.
post #6053 of 7863
There have been no firmware updates on this since 8/2012?
post #6054 of 7863
Nope, that's right, you're not missing anything..
post #6055 of 7863
Yikes. Ok thanks.
post #6056 of 7863
I've mentioned this a few times recently in this thread - I don't think Darbee Vision really wants to push these stand-alone devices, imo, I could be wrong.. maybe that's why there's no USB port on them (no intention for long term support).
What they want, imo again, is to chip it..
post #6057 of 7863
Agreed. And based on the response the Darblet has gotten from the community, I'm guessing they will have a lot of companies lining up to license their tech. They recently inked a deal Lumigen. That's a good start, but if they can get a huge company like Samsung or Sony on board, they'll be golden.
post #6058 of 7863
Very risky though to go the custom ASIC route if that's what they intend to do. I know of two broadcast products companies that went bankrupt porting their technology to a single chip. Qvis and Teranex. Qvis banked on the adoption of their compression technology in both DCI and in place of MPEG4 in the cable / DBS sector. As we know, neither happened. While a bit more successful and reborn under Black magic Designs, Teranex over estimated the market for their scaling technology in light of other competition such as Gennum. Sure Teranex was the best but consumers don't always buy the best technology. Beta vs VHS is the classic example. 6hr vs 2hr recording speed was another. Quality by it's self does not always win in the consumer marketplace.
We all here at AVS generally love the Darbee. But we are a tiny fraction of the viewing public. I'm not sure it would be a big selling point at Best Buy over similar but inferior image enhancement technologies. And you need that Best Buy marketplace to fund the engineering cost of a custom ASIC of this complexity.
post #6059 of 7863
Quick basic question about the Darbee Darblet (which I use).
Does it default to any mode (on or off) when you turn your equipment off and back on later?
I'm still not sure because of this: I use it just occasionally.
So, I turn on my projector. I wonder "Hey, is the Darblet on or off? I can't remember how I left it last time." To try to find out I have to press the "Darbee on/off" button.
Now, when I press it and it says "off" I don't know whether this is showing me the current status (e.g. the Darblet had indeed been off before I pressed the button) or whether it had been on and by pressing the button I'd just switched it off.
If you know what I mean.
post #6060 of 7863
The Darbee itself is always ON as long as it is plugged in. When you are pressing the button, (mine will simply say Darbee at 0%) you are then toggling the Darbee effect OFF. So you have nothing to worry about....
  Back to Forum: Video Processors
