AVS › AVS Forum › Video Components › Video Processors › Darbee vision darblet
Darbee vision darblet - Page 211
post #6301 of 7863
anyone else noticed the Ocule by Salt Labs and the Halite seem to be repackaged Darblet and Cobalt respectively? They are basically the same unit in a much nicer case. I wonder if it is a licensed hardware, or if Darbee is just releasing under a different name,
post #6302 of 7863
Originally Posted by Bukley View Post
Anyone else noticed the Ocule by Salt Labs and the Halite seem to be repackaged Darblet and Cobalt respectively? They are basically the same unit in a much nicer case. I wonder if it is a licensed hardware, or if Darbee is just releasing under a different name,
It's licensed, but based on the button and connector locations, I'm guessing it's using the identical boards ...
http://www.prweb.com/releases/2013/1/prweb10300656.htm
post #6303 of 7863
That's very interesting, I didn't even know about these..
post #6304 of 7863
Originally Posted by humbland View Post
With a brand new unit, I should not have to deal with the CS "dance". I can pack it up and ship it out. The battery is almost certainly not the issue. It can trigger a response from the Niles at 30ft. In any case, it's not a deal breaker, since you can use the buttons on the unit itself.
I have seen posts where people have used long runs and it works OK. HDMI handshake issues are mysterious... My 50 ft. cable is in wall, no way to change it out.
On the Z30K, the effect is pleasing, but with most content, you have to look hard to see it. If I can't get it to work reliably, it's no big deal...
My summary of the unit is in line with others. Nice, but the hardware is not ready for prime time.
If I did not have a DLP PJ, then I might hassle it. I'm willing to fiddle with it a bit more, but if it won't work all the time, then back it goes.
Darbee update:
Break for Father's Day trip, back on it.
Good news and bad. I solved the remote issue, must have been something loose as I redid everything and it started to respond. That part is working fine..
The HDMI problem is another story. By leaving the unit powered on, I can get it to work, but I have video "dropouts" with Blu-ray and DVD source. It seems to work fine with DTV...I have a distribution amp feeding 3 different displays. I'm guessing that boosts the signal enough so that it works OK with DTV. Just to make sure, I unhooked everything and took it out of the circuit. No dropouts.
I have the output from the AVR to a new 6' Mediabridge HDMI cable, then the Darbee, then a new 50' Mediabridge HDMI, to the Z30K.
I like the Darbee processing enough to stay at it a while longer.
I'm not sure what to try next. The only thing I can think of would be to get a 12' ladder and try mounting it on top of the projector, with a 3 foot run to the Z30K.
It's way up there (cathedral ceiling). I'll block out some time this week and give it a try...
Edited by humbland - 6/18/13 at 3:23pm
post #6305 of 7863
In the Home Theater Geeks podcast interview with Darblee, he said they would eventually move from a 4 chip set to a single chip set, and that this would bring the price down a lot. I wonder when the switch to a single chip set is going to happen, and if he'll include some way to update firmware.
post #6306 of 7863
can you update FW on these new devices via USB ??
post #6307 of 7863
Originally Posted by Blu_One View Post
Can you update FW on these new devices via USB ??
I don't see a USB port anywhere. I assume it's the same as the Darblet, and you have to send it in for updates.
Edited by gweempose - 6/18/13 at 8:24pm
post #6308 of 7863
I didn't see that listed as a feature. Pretty sure we are SOL until the next version of the Darblet comes out.
post #6309 of 7863
Well that's too bad then.. seems pretty simple/standard to have USB FW update capabilities in 2013..
post #6310 of 7863
Yup. And that's still the number one reason I don't have one yet. In this day and age, sending the unit back to the manufacturer for a firmware update is kinda ridiculous. Still, given what the unit offers in performance, I'd consider it if I lived in the US. But I don't. So I won't.
But if they come out with one that can be updated by the end user, I'll be all over it!
post #6311 of 7863
What exactly do you need to update? If the unit works what do you need the update for?
post #6312 of 7863
I own a darblet, but the original point is valid. Nearly any device one owns that supports firmware updates gets them, either for bug fixes, compatibility, or feature enhancements. Just because there are no issues today doesn't mean there might not be one in a month or two. I would suspect the HW design discourages them from fixing/tweaking, as there is no easy way to get the changes in the hands of customers.
Would be curious if the darbeevision tech in the new lumagen could be upgraded as part of a lumagen firmware payload. Likely yes.
post #6313 of 7863
I agree it is nice to have but if the unit has no issues I don't see it as a reason to not buy it. There are many products in life that get by just fine without firmware updates.
post #6314 of 7863
That's why I decided to get one a few months ago now.. There doesn't seem to be any issues that would require a FW update to fix, and I haven't seen anyone report any issues either. So all is good, thankfully since I'm in Canada..
post #6315 of 7863
Not knocking the darblet, but I think it's more than nice to have...and many products in life don't have firmware updates? If you listed out every piece of CE equipment you own purchased over the past few years, I'd bet more than 95% have firmware update capability. Other than the Darblet, everything I own 5 years old or less can be upgraded.
post #6316 of 7863
The cost of the Darblet would have, at least been, 20%-30% more in price if they had to include a USB board and firmware to the unit in order to do field updates. I believe Darbeevision concluded that if the units had to be upgrade the cost of sending them back would be minimal due to the weight and size of the unit. In the States it would be less than 10 dollars to send USPS.
post #6317 of 7863
Agreed, I bought mine when they first came out and have not had any issues so no need for firmware updates. As long as it works with no problem with my equipment, I'm happy.
post #6318 of 7863
I can't get the Darbee to work well (drop outs). I have a 6' HDMI to the Darbee and then the 50' inwall HDMI to the projector. When I get some time, I'll go up and mount the Darbee on top of the projector and try it at the end of the 50' run, but I'm not optimistic. Has anyone experimented with an inline HDMI "extender" to use with the Darbee? I did a search of the 200 pages and got "mixed" results. They are widely available for about $30. It seems like a possible solution.
post #6319 of 7863
Put the Darbee closer to the display / projector.
post #6320 of 7863
Or try Redmere hdmi cable for long runs, from monoprice..
post #6321 of 7863
The cathedral ceiling mount is way up there. When I get some time, I'll get a 12' ladder and fool around with the cables and AC to hook it up above the projector. Then it will be at the end of the 50' run.
At this point, the 50' inwall HDMI can not be modified. What ever I try as a solution has to involve that run. Ironically, after we had it partly installed and drywalled, we figured out a way to shorten the path. I could have gone with a 35' cable instead. Since it worked fine with the 50' run we did not tear out the existing drywall work to revamp it. If I could somehow terminate the 50' cable and attach a new end, then I could shorten it to 35', but when I last looked, there was no good way to do that...
Any thoughts on an extender/amp?
Edited by humbland - 6/19/13 at 9:44am
post #6322 of 7863
Redmere cables do not work with a Darbee in the chain that I know of. They are designed to go from source to display and the Darbee breaks that connection.
post #6323 of 7863
Ummm no. That is wrong. I use a 50ft run no problem. Many others use redmere successfully also.
post #6324 of 7863
Let me ask you this do you have a redmere cable on both sides of the Darbee?
post #6325 of 7863
post #6326 of 7863
Nope.
Oppo to Sony Headphone Box - Amazon 6 foot cable
Sony Headphone Box to Darbee - 50 foot Redmere from monoprice
Darbee to Projector - random 6 foot cable (I think it came with my oppo)
post #6327 of 7863
Nope.
So my first post should have been written better. When you try to run a redmere cable into the Darbee and then another redmere cable from the Darbee to the display this will not work. I was referring to a post done by Big Daddy over on another forum who witness this quirk when he tried to use two redmere cables in and out of the Darbee
post #6328 of 7863
Right maybe so, but you should only need one long run, not two. If needed, make that hdmi long run even longer, then just a plain old normal length cable on the other side of the Darbee, problem solved.
post #6329 of 7863
Unless Redmere cables are out of compliance with the HDMI spec, there's nothing about them that should prevent the use of a repeater device in the middle.
Are his cables on both ends of the Darblet long runs? If so, his problem is not specific to the Redmere brand. The Darblet has a weak HDMI transmitter that doesn't push the signal very well over long distances. Put the Darblet near the display, then run a long cable into the Darblet and a short one out of it.
post #6330 of 7863
One was 10' in the other one was 30' to display. So not really long runs. I would think The Darbee would not be considered a repeater.
  Back to Forum: Video Processors
