AVS › AVS Forum › Video Components › Video Processors › Darbee vision darblet
Darbee vision darblet - Page 223
post #6661 of 7863
Originally Posted by KBMAN View Post
looks like a cool baseball game.....what platform is this?
PlayStation 3.
post #6662 of 7863
Originally Posted by Louie_18 View Post
Without Darbee on left
With 55% Darbee on right
Amazing - I can't even see his nose in the one on the left!
post #6663 of 7863
Darbee on left, no Darbee on right:
post #6664 of 7863
Gee! - do they make Darbee mirrors that work this way too???
(They'd sell a TON! biggrin.gif).
post #6665 of 7863
Originally Posted by terminal33 View Post
I now have it with my Benq W1070 projecting a 105" screen. I'll have to say that the difference is more noticeable, but I'm not super impressed yet. But I'm not giving up yet either. I tested out a few BD's and settled for HD 70%, a little higher than most folks I think. I used the same setting for 3D (Avengers, Avatar) For animation and CGI (Avatar), I used Full Pop at 60%. Same goes with Xbox.
Are there some general guidelines for BD's, 3D, animation, CGI, and gaming? For instance I know the Darbee can be cranked up higher with a better source.
1.) But can/should 3D be cranked up even higher? Lower?
2.) Is Full Pop generally better for CGI and animation? (I've read that some people would rather use a lower Full Pop setting than a higher HD setting.)
I know ultimately it's all up to my preference, but I just wanted to see if there were some agreed upon guidelines. Thanks!
Projecting on 120" screen. Darbee set at 60% HD. Anything more and faces look white-ish. Exception was 'Avengers', I had to set Darbee at 75% HD to get the picture I wanted.
For animation, switch to 'Gaming', same %age.
For 3D, I have now started using 50% Full-Pop, to compensate for drop in contrast and brightness.
post #6666 of 7863
post #6667 of 7863
I just got mine, I have to say I am impressed, it is quite an improvement in contrast and detail. Have it set at HD 50% for Bluray movies. Haven't gotten to games or 3D yet.
118 inch screen and Sony HW50es
Edited by JacobC1983 - 7/30/13 at 5:50pm
post #6668 of 7863
I seem to be liking 65% on the "Gaming" mode for my 70 inch LED LCD Sony.
post #6669 of 7863
Originally Posted by Hyabusha View Post
What's the vote for turning the Darbee off? Unplug It, or just leave It on 24-7?
Buy a green power strip. Plug the TV into the master outlet and the Darbee into a controlled outlet. The Darbee will be completely shut down when the TV turns off. Your settings will be saved.
post #6670 of 7863
post #6671 of 7863
Tried that with my Darblet 5000 and it does not work. The boot time on my Darblet is longer than both my F8500 and AV Receiver causing handshaking problems. Leaving the Darblet on 24/7 is best for the Darblet and never have any startup problems.
post #6672 of 7863
Some strips build in power-on / power-off delays to be kind to circuits. That would probably be enough to screw up the handshake. Not sure if yours does that. Probably doesn't matter much anyway -- like you, I usually leave the Darblet untouched.
post #6673 of 7863
I have 3 Over The Air HD DVR receivers that have no "off" button. Their hard drives run 24/7. They were never designed to be shut off. And they even have moving parts. All three are over 4 years old and still running like champs. Point: I wouldn't worry about it. Seems to be the way electronics are going these days. Do any of you turn off your cell phones? I know I never do. Just the ringer.
post #6674 of 7863
Originally Posted by muffinmcfluffin View Post
Blu-rays/TV: Hi-Def 50%
Animated/3D content: Hi-Def 75%
I press one button on my Harmony remote, and alongside everything else that changes, it shifts the percentages up and down seamlessly for me.
Is anybody daisy-chaining two Darblets these days?
I am.
Mark
post #6675 of 7863
How does daisy chaining two darbletts help PQ over just one darblett?
post #6676 of 7863
I am also. One is set to HiDef at about 50%. The other is full pop at about 25%. Full pop actually has some great attributes but only in small doses. Adding it to HiDef adds a little more depth and "clarity" with no artifacts. Game setting seems to make bright areas too bright for me and am not using it.
post #6677 of 7863
Originally Posted by Jay5298 View Post
Question about Darbee placement.
I finally got my RNG-200 from Comcast and now I can watch TV with the Darblet. I've briefly watched some scenes from various Blu-rays and watched some sports on TV. I feel that I definitley fall into the "subtle" difference category. I have a Runco LS-5 DLP projector that is professionally calibrated. Screen size is 110" diagonally and I sit about 13 to 14 ft away. I do prefer the image with the Darbee than without, but I haven't been WOWED yet by it. Which brings me to the question, is it better to have the Darbee close to the display as far as connectivity. Right now I have it in my rack which is about 25ft away from the projector. I could put it closer to the projector using a 6ft cable, but if it works at 25ft will I notice an improvement at 6ft? I know this is probably a stupid question but I had to ask.
Try turning the Darbee Setting up or the unit to a more aggressive Mode (you didn't mention what Mode or Setting you are using) and when you see unwanted artifacts, reduce the setting until you are just below the visible artifacts.
That might be the best way to find your sweet spot for good enhancement for your own visual system.
If the HDMI chain doesn't break, there is no theoretical benefit to Darbee processing where the Darblet sits in the chain.
-DD
post #6678 of 7863
This is the first time I've had an issue with my Darbee. I just hooked up my new Panasonic PT-AE8000 projector and tried to play my ps3. For some reason I wasn't getting a display, so I reset my display settings and it went back to 480p. I chose the automatic display setup and I lost my picture again. When I chose custom and tried each resolution individualy, it became clear that I'm having issues anytime the resolution is set to 1080p.
When I tried my Wii U which is set to 1080p, it did the same thing, no picture. I hooked my Ps3 directly up to my projector and was able to view 1080p. I then took the Darbee out of the chain and hooked everything back up to my Onkyo Receiver and 1080p worked. Not sure what the heck is going on. Ive had this same setup with a different projector and 3 other displays and never had a problem. Any idea what could be going on. Do I have a defective Darbee???
post #6679 of 7863
Sounds like it just doesn't play well with your new Panasonic projector for some reason...some sort of handshake issue it would seem... Are there any HDMI input settings that you can adjust on your Panasonic? Make sure any CEC HDMI settings are turned off and so on...try switching around where the Darblet is located... closer to the projector or receiver, etc... I assume you have rebooted the Darblet?
post #6680 of 7863
I have not tried that yet...... Not sure why I didn't think of restarting the Darbee. Thanks!!
post #6681 of 7863
Got it fixed because of your recommendation Dean. I put the Darbee closer to the projector and its working great now. Thumbs up buddy!!!
post #6682 of 7863
Originally Posted by giomania View Post
I am.
Mark
I just ordered a second Darblet about a week ago, and it's probably laying outside my house right now.
Is there substantial benefit in daisy-chaining it where I should add it with my bedroom 59" plasma (where I watch more movies) as opposed to putting one in my family room with our new 60" plasma (where mostly just cable TV is watched by my parents)?
post #6683 of 7863
How much do you like your parents?
post #6684 of 7863
Hey fellas,
Hope everybody is having a great wknd! I have yet to see what my Darbee will do as my theater reno has been put on a short hold do to a family member passing. But I've been able to keep up with the forum. One question, what exactly is the benefit of daisy-chaining two (or I've even seen three) Darbees? I've haven't read a good reason/ discription of what it does. I've read tons on the benefits of the Darbee itself. So anyone with experience of daisy-chaining please enlighten me. Thanks, migraine
post #6685 of 7863
Originally Posted by migraine24-7 View Post
Hey fellas,
It's funny you should ask - sorta. I have read several people asking if the Darbee was worth the price. Those thinking of daisy chaining are asking if the Darbee is worth twice the price - sorta.
For me, I could justify about $250 (on sale) for the improvement the Darbee brings to a display. So I bought 2 for 2 different displays. I cannot imagine spending $500 to improve just one display, no matter the improvement. But that's just me. Everyone has a different value scale.
post #6686 of 7863
The cool thing for you is that now you can experiment with a daisy chain at no additional cost. Who knows, you may have taken the first step towards owning 4 Darbees. 👍
post #6687 of 7863
post #6688 of 7863
Wow... really?? You can't justify spending $500 to improve just one display? You haven't caught the disease, man... you haven't caught the disease... I spent many thousands on a CalMAN/C6/Lumagen bundle to do automated Color Cube calibrations on my "single display". The results are a stunning walk-through-the-window experience. Don't limit yourself with arbitrary cost ceilings! Spend your children's education! Inheritance? Let them work for it! Spouse? Cash out that life insurance policy... feed the disease!
post #6689 of 7863
"To love oneself is the beginning of a life-long romance." ~Oscar Wilde
post #6690 of 7863
  Back to Forum: Video Processors
