AVS › AVS Forum › Video Components › Video Processors › Darbee vision darblet
Darbee vision darblet - Page 248
post #7411 of 7863
Originally Posted by AustinJerry View Post
The effect is subtle, and to notice it, you have to look at specific types of images.  For example, in an outdoors scene with either trees in the foreground, or buildings in the background, pause the video and toggle the Darbee enhancement on and off.  Look for changes in edge details in the trees or on the buildings.  Or look at a live TV broadcast with close-up images of faces, e.g. the evening news.  Pause the video, toggle the effect on and off, and look for changes around eyes, in facial shadows, and especially the hair.  Increase the effect percentage until you can notice a difference, and then you will be convinced that something indeed is happening.  Then you can dial the effect percent down until the effect is most pleasing to you.
Report your experiences, please.
I do not notice a big difference. I would sum up my improved video quality as AustinJerry put it... "Subtle". Anything more than that and the viewer is buying into Darbee's marketing strategy. IMO... biggrin.gif
post #7412 of 7863
Sitting 10' back from a 10' wide screen it's more than "subtle" and I'm not buying into any "Darbee marketing strategy". My wife wants to sit up front in the 1x sw seats now and doesn't know why. But she really noticed a difference with no placebo effect whatsoever. "Did you calibrate it? Did you put a new lamp in? What did you do?" She has no clue I installed a Darbee, has never heard of it, nor would she really understand it anyway. She just wants to sit up front. I would not attribute that to "Darbee marketing strategy".
post #7413 of 7863
Thanks Jerry, but maybe its not on, or is defective then, because I'm seeing NOTHING.
Please tell me exactly how you "toggle the Darbee enhancement on and off".
With the remote's on/off? Because if so I've tried that too.
I've experimented with 25% all the way up to 75%, scanning back & forth, split screen (can't tell which side is "Darbeeized", etc.
I've also experimented now with several Blu-rays, several SD DVDs, and several HD cable broadcasts...
I just don't see it...that's why I think maybe its defective, and its just passing through the video?, but then would the 'demo mode' operate?
post #7414 of 7863
Well, it is possible that you unit is defective.  The on/off button is the upper left button labeled "Darbee On/Off".  BTW, you can dial up the effect all the way to 120% for testing.  Here are two pics showing the difference off vs. on (Warning:  ugly pics!).  If you can't see any difference, then we know where the problem is.  ;)
post #7415 of 7863
Or this one:
post #7416 of 7863
Here's what it should look like. I'm using the Blu-ray disc of Drive as an example.
1) A | B
2) A | B
3) A | B
4) A | B
5) A | B
6) A | B
Here is an example from The Avengers, where I have a close-up of Tony Stark's face in the Iron Man suit. I captured 25% intervals for HD and Gaming (up to 100%), as well as a 0% shot.
Normal - 0%
HD - 25%, 50%, 75%, 100%
Gaming - 25%, 50%, 75%, 100%
And then I have a video where I do some wacky stuff flipping back and forth:
Sorry for the incredibly amateurish video.
post #7417 of 7863
I have Darbee Drablet DVP 5000 coming tomorrow from amazon; I sure hope it lives up to the hype that I have been reading about it. I plan on using it on a professionally calibrated Panasonic 60VT60. Reading from this forum post and reading reviews from highly respected reviewers they seem to like the device, so I should be happy, or I hope so anyway.
post #7418 of 7863
For me the difference was more than subtle... it was obviously enhancing the quality of the picture... especially noticeable with quality HD like Blu-ray. The effect was clearly noticeable when toggling between effect off or on. Maybe something wrong with your darblet, or possibly something in the chain.
EDIT: Hmmm! I was replying to another post... don't know how my post ended up here... confused.gif
post #7419 of 7863
I notice the same enhacements as the video someone posted earlier in this thread. I still think that it is subtle. Don't get me wrong, I do think that it is an improvement, but not all that drastic and I won't be getting rid of my Darbee because any improvement is better than none.
post #7420 of 7863
I've read through the threads over the last couple days and can't seem to find a specific solution or issue the same as mine. Hoping someone can weigh in.
I just received the Darblet for Christmas. What an awesome device. However after about 40 minutes of getting me addicted to a killer pic it stopped working.
The lights and all on the Darbee still work but my projector says "No Source." I have all my components (Oppo, AppleTV, Direct TV) running through my receiver by HDMI and then receiver to Darbee to projector.
Anyone have the same issues? Ideas?
Thank you.
Components:
Integra DTR 30.1
Oppo BDP 103
AppleTV
Epson PowerLite Pro 1080UB
post #7421 of 7863
Thank you.
Components:
Integra DTR 30.1
Oppo BDP 103
AppleTV
I had the same issue. In my case the Hdmi input #1 on my projector went bad. Moved to input #2 and I'm back in business.
I'd start there. Then I hook the Darblet directly to a source ie oppo and see if it works then. Then start check Hdmi cables. Let us know how u come out. Good luck!
post #7422 of 7863
Great! Thank you. I'll give that a try.
Regarding the HDMI cables. I'm using samsung and sony "high speed." From what I've read those should be good, right?
post #7423 of 7863
Try putting the Darbee nearer to the projector side. Also make sure turn deep-colour beyond 30-bit (10-bit per channel) off.
post #7424 of 7863
Unf
unfortunately I've had far far faaaaaaaaaar too many long-length HDMI cables under Sony brand. I've never used Samsung branded cable so I don't know.
post #7425 of 7863
Actually, 'upon further experimentation'...
Last night I did 'round three' with the Darbee, and was able to effect some positive noticeable changes.
Its still set at 45% on HD - and I had to freeze motion the HD picture and then toggle it on and off to see it, but I was able to now detect some subtle positive improvements! Same with SD sources.
Nothing drastic, or even 'substantial', but I can now see some effect.
With a moving picture its very hard to see its effect.
Its a *VERY* subtle effect though at 45%, so I might try to boost it higher and see how high I can push it while still avoiding any digital artifacts.
Still not sure if I'll keep it, but at least now I know that its working and better know how to make its effect noticeable...
post #7426 of 7863
After owning and installing a bajillion Darbee, I'm suspecting there may be something wrong with your projector. Is it perfectly focused? Has it been professionally calibrated lately? 100% of my clients see "dramatic" difference at 45% HiDef (as opposed to "subtle"). And no, none of them pre purchased the Darbee, all I did was put the Darbee in the chain and I showed them with Darbee ON and then I say "let me show you something" and turn off the Darbee processing. All of them asked "why's the picture so blurry now?". Only then I explain to them about the Darbee.
As I am NOT a Darbee dealer, they buy the Darbees from various sources and I make zero comission from any of the sale.
What I'm trying to say is that none of them knew about Darbee's existence and yet all of them (more than 60 projector setups and more than a couple of dozen TV setups this year alone) see dramatic improvements done by the Darbee.
post #7427 of 7863
I usually run mine on HD at 65% for Blu-ray, and 45% on SD. That seems to work best for my set-up.
post #7428 of 7863
Thanks for the response David, but I don't have a projector set-up - I'm running it to a 65" Panasonic ST30 series plasma.
Like I mentioned before, its always had a great picture - with the Darbee attached, or not.
The effect is subtle so far and I intend to 'play' with it some more through the weekend, and reserve final judgment for a few more days.
One nice thing though is that I've got it hooked up to my display with a 3 foot HDMI cable w/zero issues! (many have reported problems using less than 6 footers).
(Though I'd certainly suspect that projector owners with the bigger images/screens would see the most improvement just because larger displays would benefit from the better (perceived) resolution.
post #7429 of 7863
What is your viewing distance? For a 65", if your viewing distance is further than 8ft away, at 45% HD, the Darbee effect WILL be subtle. You may need to crank it up to 65% HD.
post #7430 of 7863
PS: I always use 1 ft HDMI with the Darbee and never failed too smile.gif
post #7431 of 7863
What I can't understand is why you claim to see very little effect, yet you only have it turned up to 45%.  The correct approach is to keep turning the effect higher until you do see a difference, learn what the effect looks like, and then dial it back to a level that looks best to you.
I have a 65" 4K LED display, sit at ~10ft away, and use 60% HD.  At 60%, there are no unwanted artifacts, but I can clearly see a difference when I toggle the effect off and on.
post #7432 of 7863
I have a 159" screen. And my projector is a Mitsubishi HC 6800. I hooked up the Darbee and didn't tell my wife. She came down and said did u recalibrate or something. I said "no why"? And she sat down and said the picture is great. It was good before but now it's just better. I explained the Darbee and for once she didn't even ask what it cost! Now that's a difference!
post #7433 of 7863
That was my approach too Jerry, On my 70" Sharp I am using anywhere between 55% HD to as high as 70% HD and one of the reasons is because I sit 13' from the screen.
That's a great story. My wife responded the same way after installing the Darbee.
post #7434 of 7863
Makes 3 of us so far!
post #7435 of 7863
Our typical viewing distance is 9 to 10 feet away, but I've been experimenting with this from about 6 feet away (moved a chair up close, etc.).
I'll try it again with higher settings tonight (I've had it up to 75%, but with some noticeable digital artifacts).
post #7436 of 7863
IMHO, anything beyond 65% introduces too much artifacts (even on 55" viewed from 10ft away). However, I've seen some of my clients even use 85% on their front projection setup eek.gif
post #7437 of 7863
I sit about 8' away from a 73" and have my Darbee at 45%. I like it more on the subtle side. Just a pinch more depth and detail.
post #7438 of 7863
Originally Posted by Type A View Post
Did you verify the Darbee is in good working order? Tried the same set up with a different display, tried a different cable, took the Denon out of the loop, process of elimination sorta thing...
tried again and I got it to work between the Sony 5100 & my Denon receiver. Unfortunately I can't get it to work from the receiver to projector which is really where i'd like it to work since I can get the benefit of all 3 of my sources.
Originally Posted by DaveN View Post
Lumagen makes an HDMI amplifier that fixes these type of issues. The signal strength is adjustable. I used one with a Sony VPL=VW100 and I went from no picture to solid. I have a new PJ and new room so I am no longer using it.
PM me if you are interested.
Dave
Originally Posted by mark haflich View Post
Hi Dave. The HDMI-HDMI extender by Lumagen does not amplify the signal. It has four selectable settings which adjust the equalization and four additional settings which adjust the equalization and correct the timing. All done with one box at the display end of a long cable. I am using these in some installations and in my HT which you are familiar with. However, if a signal is encrypted with HDMI 2.2 as out of the Sony server, I can't get it to work. I will shortly be trying a Kordz extender which has boxes and short HDMI dongles on each box at each end of the HDMI run and is plug and play with no adjustments possible. I have been told that it will pass HDCP 2.2. What projector have you switched to?
Dave I'll PM you. Should it work for me on my Denon receiver going to the projector even though I'm running a sony dvd player? Also, can I put this at the receiver end in the media closet or do I have to hook this up where the projector is?
I'm sure you've probably checked this but is the Redmere running in the correct direction? It isn't like a typical Hdmi cable. It has to be run with a specific end at the source and other end at the display. If it's reversed it won't work. Also what length Hdmi are you using for the shorter cable? Many people have had issues with cables shorter than 6 feet. Hope something I've said here helps. Have a safe and Merry Christmas.
Yup, definitely right direction. I tried 2 different cables, at 6ft & 10 ft.
Originally Posted by Korszo View Post
I posted this in the "Digital Hi-End Projectors" forum this morning. Don't like to double post, but this information is probably more appropriate and helpful here. Some recent Darbees were shipped with the wrong power supply ...
Check your Darbee's power supply. If its 9vdc, it is the wrong supply. Should be 5vdc. I had this problem & waisted a lot of time only to find out through the vendors testing, and his contact with Darbee the supply was wrong!
Very frustrating. Another indicator is the Blue LED will stay on all the time, even with no cables connected. It should only be on when video is present at the input.
Hope this helps ...
it's 5vdc. My blue light is on, and the green flashes.
I think though ultimately I have hdmi length issues since even without the darbee after rehooking cables up I wont get a picture without restarting lots of things and luckily eventually a picture shows up after I plug and unplug the projector and the receiver.. frown.gif
wondering if the lumagen, or monoprice http://www.monoprice.com/Product/?c_id=109&cp_id=10110&cs_id=1011012&p_id=8120&seq=1&format=4#feedback or gefen product would work?
it'd be cheaper than getting a second darbee or even 3rd. I want my roku, boxee and eventually HTPC to get the benefit of it, so would like to go from receiver to darbee to projector.
post #7439 of 7863
I cant get my Oppo BDP-93 HDMI 1 output to play nice with my Yamaha RX-A3010 AVR, turns out the QDEO video processor for that Oppo output is just fickle. Thats one of the biggest drawbacks of HDMI is that sometimes components just dont play nicely. I would experiment with your video processing settings within the AVR, are you using through? Its a long shot but I would also try different cables. I dont blame you for wanting the Darbee to work for all sources via the AVR output, hopefully further experimenting with be fruitful.
post #7440 of 7863
Just wanted to post a very quick review on my findings:without being too rude,the Darblett was a complete waste of money.The artifacts (random,frequent snow), as well as ringing make the cure worse than the illness.Tried in in 2 of my 3 systems,same result on both.Not going to waste my time any further.This is either a defective unit that misbehaves, or a perfectly working Darbee that is terrible.It's going on FleaBay, with an accurate description tomorrow.
 You don't get anything for nothing, I guess.If this particular unit made your HT video sources look better, they must have been terrible to begin with.
  Back to Forum: Video Processors
