Originally Posted by myoda
The optical out of the tv will pass DD 5.1 from devices connected via HDMI. I have a Sony BDP-S770, a Western Digital TV Live Hub connected directly to the tv, and the optical out does pass DD 5.1 from those sources passing though the optical cable to my receiver. Your illustration shows an Analog connection.
1.) The note that is highlighted in the user manual is refering to the optical output diagram not the analog connection.
2.) Are you sure your receiver in not converting 2 channel PCM into 5.1 via Dolby Pro Logic?
It's really laughable that a manufacturer would include a feature like this and the area in which it's supposed demonstrate its worth is where it fails worse than no enhancement at all!!?
