Originally Posted by urbanmapper
Someone made the point that with an articulated mount it isn't just the weight, but the fact that swinging it will exert a lot more pressure because the lever is longer. Is this a worry?
What do you all use? Do you think I can use the 26-47" mount? Thanks!
Thanks again!
Thanks again!
Wish I could help you with this, but I've got a standard flat wall mount. I got mine from Monoprice.com and it's an ultra-slim type. I think I paid about $30 for it and it works great with my Sharp LC-60-640U. My TV hugs the wall and it helps a lot with improving the side viewing angles from the corners of our seating arrangement.
I wanted one but it wouldn't fit into the spot where it has to go in my living room. The 60" I have is still a step up from the 55" HDTV it replaced. Yes, the IP control is excellent!
